bought evo, Rom on car
But if you already have a mbc just turn it down two lbs and flash a sticker back on.
Okay i fixed the above mentioned definition errors, and this is what shows up, compared to a stock timing map this doesnt look too bad to me, but like i said im not a tuner so what do you guys think?
should i still revert to stock maps? what does the infamous block of 8s mean?
The sea of 8's means that blatant block of 8* of timing on the right side of your map. It is overadvanced in many load/RPM areas, very knock prone, and potential to spin a rod bearing (if you're lucky) if you beat on it long enough.
Just get it retuned properly. Start with stock maps. It's not that hard to tune yourself if you have the ability to log with a Tactrix cable. Plenty of people here will help you along the way.
roadspike linked me here in hopes to help the guys block tune. bvasquez12 if you have a tactrix cable and evoscan and a loggable wideband i can fix you remotely.. if not you can purchase it from me. just let me know.
if it wasnt for roadspike id still be duh'ing about how to tune speed density.. he was of great help and is very knowledgeable in general.
btw thanks roadspike
Mikey
