Anyone seen a 1.80E-05 error in logs?
Currently utlizing a 3 port bcs and ECU based boost control. Finally dialed in my boost map, or was trying to, and I get a weird error within the logs specificaly in the Boost Error column. Every now and again, under full boost, in the middle of the power band, I will get a 1.80E-05 error. Only in the Boost Error column is where this has shown up. Power is not lost as well as no Knock detected, but curious as to why it is showing up...
thanks in advance,
thanks in advance,
Bump to top. double checked my logs, 1.80E-05 shows up in the same log, boosting under 22 psi with what should be an error of .4xxx gives that as a boost error, two rows down when boosting at 21 psi, error should be 1.xxxx but reflects 1.80E-05. Some one has to know something here...
Thanks in advance.
Thanks in advance.
tsitalon1
11
Aug 17, 2010 08:02 PM
