Is there any potential for ECU damage in 3 ports without resistors?
Old Jun 14, 2011, 06:26 AM
Evo8uk's Avatar
There seems to be a lot more people running mac valves and gm solenoids without resistors these days has anyone ever damaged a stock ecu or is it even possible to damage the stock ecu by using a 3 port that isn't matched to the stock BCS in terms of current draw.
Old Jun 14, 2011, 06:45 AM
Magnumpsi's Avatar
Not that I have ever heard of or seen. I have done lots with no issues.
Mitch
Old Jun 14, 2011, 10:30 AM
mrfred's Avatar
Your thread title is a bit misleading. Guess you're trying to attract attention?
I run my GM 3-port without a resistor. Been like that for a few years. razorlab has been doing it for many years (3+) on several race Evos that he tunes.
Old Jun 14, 2011, 10:33 AM
EvoM Administrator
Noize's Avatar
I totally agree, I edited it.
Old Jun 14, 2011, 12:14 PM
Evo8uk's Avatar
I know it's probably been covered a thousand times before but as Ive only got my iPhone at the minute with no laptop access searching is taking forever, just how far out are these type of 3 ports compared to the stock BCS in terms of resistance?
Old Jun 14, 2011, 12:15 PM
Evo8uk's Avatar
Sorry about the the thread it wasn't intentionally meant to be misleading!
Old Jun 14, 2011, 12:28 PM
EvoM Administrator
Noize's Avatar
I know you weren't, buddy! I just did it to help fellow 3 port owners sans resistors to not click this thread in panic (like I did).
Old Jun 14, 2011, 01:59 PM
charlie.tunah's Avatar
heres a link to the evoecu wiki page. Some of the popular 3 port resistances are listed.
http://evoecu.logic.net/wiki/3_Port_Boost_Control
Old Jun 14, 2011, 03:38 PM
Evo8uk's Avatar
Cheers for the link it seems that the GM is quite close in terms of resistance has anyone tested a grimmspeed as this is meant to be designed to work with the stock ecu I'd be interested to see the resistance.
Old Jun 14, 2011, 05:24 PM
mrfred's Avatar
I tested that one as well. Can't remember the resistance, but if you search in the ECUFlash forum, you'll find my results.
Old Jun 15, 2011, 06:04 PM
Vigman's Avatar
You do not want to wire it without any resistor because youŽll take the risk to burnout the output transistor in our ECU.
For a GM, resistor has to be 5.8 ohms - 3Watts.
Cheers,
C>
Old Jun 15, 2011, 07:54 PM
mrfred's Avatar
Cheers,
C>
No one has ever burned out the circuit in the ECU when running without a resistor. Its an early concern that has proved to be unwarranted.
Old Jun 16, 2011, 09:24 AM
Evo8uk's Avatar
Thanks for the replys puts my mind at ease about running a 3 port without a resistor as from what I've read using a resistor can reduce the speed of the solenoid.
Old Jun 17, 2011, 05:25 AM
Evo8uk's Avatar
Just out of curiosity if you could damage the ecu by using a 3 port without a resistor what exactly would happen to the ecu would you lose boost control altogether or would it still work but incorrectly.
Old Jun 17, 2011, 01:08 PM
mrfred's Avatar
The circuit would burn out, and there would be no boost solenoid control.
Quick Reply: Is there any potential for ECU damage in 3 ports without resistors?
