ECU Boost on JDM Evo VIII
Old Mar 21, 2012, 04:21 PM
EvoIIIAj's Avatar
Hi all,
As you all are aware, or should be aware I guess. The JDM VIII does not come with a factory map sensor like the USDM VIII does.
On your ECU's I think pin #73 goes to the factory map sensor.
I don't have anything in pin #73 so my friend as I were discussing possibly putting a connector in there that's wired to the output wire of my electronic AEM boost gauge and changing up values in ECUFlash/EvoScan and then start reading/controlling boost through the ECU.
Has anyone ever attempted this?
Here's the JDM VIII pinout:
Old Mar 21, 2012, 10:01 PM
HyperDisorder's Avatar
I use pin 73 for my LC-1 logging with 3C, and pin 92 for my MAP sensor logging with 38. If your rom ID is 96260009 then I think that you'll need to change the address at 3C to 8409, but if you're on 93660005, then you won't have to change any addresses - I didn't.
Old Mar 27, 2012, 04:25 PM
EvoIIIAj's Avatar
Thanks.
Old Mar 27, 2012, 04:40 PM
No worries. Happy to help. Get in touch if you need anymore help or suggestions for the install.
What's your rom ID?
Old Mar 27, 2012, 04:43 PM
EvoIIIAj's Avatar
Thanks bud. I'm on 96530706.
Old Mar 27, 2012, 04:45 PM
AndyCT9W's Avatar
I thought the JDM evos came with better map sensors than the USDM? My JDM IX has a factory 3 bar map sensor, I thought VIIIs would be the same.
Old Mar 27, 2012, 04:46 PM
EvoIIIAj's Avatar
Yeh the JDM IX comes with a map sensor from factory but the JDM VIII's have none.
Old Mar 27, 2012, 04:51 PM
JDM 8's are the unlucky ones. Got a shop to drill and tap my intake manifold to fit the map sensor. At least the intake still had the mounting boss.
Old Mar 27, 2012, 04:59 PM
EvoIIIAj's Avatar
I guess I'm on a USDM ROM right? I think? Lol.
Wondering if I can run a wire from pin #73 to my AEM Boost Gauge's output wire?
Pin #73 is map sensor signal for USDM Evo VIII
http://evoecu.logic.net/wiki/USDM_VIII_ECU_Pinout
Old Mar 27, 2012, 05:00 PM
EvoIIIAj's Avatar
Just noticed the USDM VIII ECU has 4 connections on the back also, vs the 3 on the back of my JDM VIII ECU.
Old Mar 27, 2012, 05:47 PM
Don't worry that it's a USDM rom. It just matters that you have the 3 plug ECU. Pin 73 will be fine. If for some reason you end up with issues, it'll be easy enough to convert you to 96260709. It the rom I run.
Old Mar 27, 2012, 06:17 PM
EvoIIIAj's Avatar
Cool. In the near future I want to do it so I can log boost with tscompusa.
Old Jun 13, 2012, 08:41 PM
EvoIIIAj's Avatar
Hyper... You around? What's the easiest way to get me to log boost in EvoScan right now? I have an AEM digital boost gauge if that helps lol
Old Jun 18, 2012, 12:26 PM
Hey, have you wired it up to pin 73 yet? Or 92 or 93 as they are the spare pins that are ADC's. I'm not running 9653 so then I can only suggest you log 3C for pin 73, or 38 for pin 92 or 39 for pin 93.
Old Jun 21, 2012, 09:42 AM
EvoIIIAj's Avatar
Nope, haven't wired anything up yet, just want to be sure before I start messing with the ECU like that!
Quick Reply: ECU Boost on JDM Evo VIII
