anyone logs Knockbase&Knockadc ?
Old May 28, 2012 | 04:41 AM
stunt2's Avatar
Question anyone logs Knockbase&Knockadc ?
im Merlins ecuflash guide this method is stated as one of the good way for determining false knock. spots where Knockadc(pink) spikes over Knockbase(yellow) are real knock, other is just a mess of engine noise. anyone uses this method succesfully ?
image host
Old May 29, 2012 | 03:11 AM
stunt2's Avatar
any input ?
Old May 29, 2012 | 06:19 AM
C00LM4N's Avatar
I tried to use it one time with no result.
As I understand, logging speed it too slow, so I've managed to get a clear knock image only once. Knock Sum can be 20-25, but Knock ADC won't cross Knock Base. I think Knock ADC changes very rapidly.
Old May 29, 2012 | 06:33 AM
stunt2's Avatar
nearly same results for me too, but maby that's phantom knock?
interesting if someone has double checked it via det cans while logging knockADC and knockBase
Old May 29, 2012 | 07:32 AM
C00LM4N's Avatar
Whether it is phantom or not, Knock ADC must cross Knock Base. This is the raw data to calculate Knock Sum.
Old May 29, 2012 | 01:19 PM
Dynotech Tuning's Avatar
The idea is to take notice of the average noise floor vs. the KnockBase line. If it appears that the noise floor is very close to the base line at all times, the engine may be noisier overall. If you see giant spikes, those can still be false knock since the knock sensor can't tell you if it's from a brace hitting the downpipe or a true knock event. Also, lowering boost, changing to a higher fuel octane and minimal ignition timing can help prove/disprove false knock.
At first glance of the sample graph, it looks as though the knock multiplier LOW and MID rpm ranges are a bit noisy, though the knock multiplier HIGH looks like its leaving plenty of noise floor headroom. Again, this would a situation that needs to be confirmed before making adjustments. It seems that on most standard logs I have seen, knockFILTADC is, on average, half of KnockBase.
-Jamie
Old Jun 1, 2012 | 02:14 PM
burgers22's Avatar
EvoLive map is the way forward here. You can get hundreds of samples a second with the DMA logging. Live map thread
Old Jun 2, 2012 | 03:08 AM
C00LM4N's Avatar
If only 89970010 or 80700010 have DMA...
Old Jun 2, 2012 | 10:38 AM
burgers22's Avatar
You could ask donner and ziad if they could do it. I know they are both pretty busy, but you ever know.
Old Jun 2, 2012 | 05:52 PM
I agree, DMA is the best way to make use of this.
-Jamie
d613
Sep 22, 2016 11:14 PM
stunt2
Aug 19, 2013 09:49 PM
stunt2
Nov 23, 2012 03:57 AM
mchristian
Nov 18, 2012 11:39 AM
stunt2
Apr 28, 2012 10:43 PM
