crazy timing jump in log
Old Apr 17, 2014 | 12:31 PM
crthomas1952's Avatar
I don't know if this has anything to do with the crazy way it has been running (below), but my oxygen sensor went out about a week after I posted the message below:
So my exhaust housing broke where it bolts to the manifold and I replaced my whole turbo with one bought used. Both turbos oem Evo VIII. Just finished and test drove it a few days ago and it is really acting weird. It knocks all over the place and at least three times I've had a "backfire" incident that sounds like a pop and I can feel as a surge or pause (yeah, opposites, I know).
So I've started taking out timing and logging with EvoScan and I'm seeing huge differences. It is getting up to the 250 and 260 load cells where 200 was tops before. i got a really bizzare log this morning. I was doing a pull at wot and the timing was zero degrees for over 30 lines then jumped to 17 degrees advanced in the next line. That gave me six counts of knock. Log is attached; line in question is almost at the bottom.
Any advice or suggestions greatly appreciated.
I will update again after the new sensor is in and I check the logs.
File Type: pdf
Old Apr 17, 2014 | 04:05 PM
ReaperX's Avatar
Post a screenshot of the timing map please. Also what are you using for boost control, and does the wg actuator have any additional preload in it?
Old Apr 18, 2014 | 08:53 AM
Thanks for your time, Shaun. Boost is controlled with ecu; no mbc or other add-on. I don't know about the actuator preload. How can I find out?
I'll post the high octane fuel and ignition map screenshots here for the above log. Then, I'll post them as they were before turbo change below.
Attached Thumbnails crazy timing jump in log-mod13.png   crazy timing jump in log-mod-13-fuel.png
Old Apr 18, 2014 | 09:30 AM
I had really cut back on the knock by decreasing timing advance before the turbo switch, but I was still getting just a bit. Here is a message I sent to my mechanic at that time:
I had dialed the timing back in a few of the load cells based on the previous logs that I posted on evolutionm. I took it out to log again and for a while I thought I wasn’t going to be able to get the cel to flash at all. But, it finally did one time. When I looked at the logs, there were multiple instances of 1 or 2 knock counts, but only one line that had 3. (That answered my question, I think, as to whether it flashes with only 1 knock, or whether there had to be 2 or 3. Looks like 3.)
I feel SO much better now. I’m going to Barber next weekend, and I was afraid I’d have to cancel with the way it had been knocking. Now, even if I can’t get into the ecu again, I think some octane booster and race gas will keep me safe for the weekend.
The part of that log with the 3 counts is attached.
I saved the attached maps the next day, and I'm pretty sure I was able to flash them into the ecu. So, these would be the maps that were in the car before and after the turbo switch. (Even with adding Torco to boost the octane, I still got a little cel flashing at the track.)
I'll post the logs of the car with the replaced turbo in the next message, in chronological order.
Attached Thumbnails crazy timing jump in log-mod12-fuel.png   crazy timing jump in log-mod12.png
File Type: pdf
Old Apr 18, 2014 | 10:19 AM
So here is the first log with the turbo replaced, with the maps mod12 above (EvoLog1). Then, I took some more timing out, flashed the revised map back in, and recorded the second log (EvoLog2). I didn't save that revised map.
Before the log attached to the original post above was taken, I decreased the AFR by 0.2 in all the cells with load >100 and RPM > 2000. Then, I saved maps mod13, above.
File Type: pdf
File Type: pdf
Old Apr 18, 2014 | 01:31 PM
todd6027's Avatar
dont see any wideband afr in the logs ???
Old Apr 20, 2014 | 11:46 AM
So yeah, there is a wideband installed. I just need to figure out whether I need to connect with a separate cable or whether it is wired in so I can just check a box in EvoScan. It is an AEM, and there are 2 different ones that can be selected in EvoScan, so I guess I'll just try selecting one, and maybe then the other.
Old Apr 20, 2014 | 12:14 PM
todd6027's Avatar
cool , else your just chasing your tail .
nj1266
Jan 25, 2026 01:43 AM
BigJohnnyturbo
Sep 4, 2017 01:18 AM
Evo_Goodness
Jun 1, 2017 03:36 PM
mrfred
Nov 10, 2015 06:48 AM
nothere
Jun 23, 2007 05:48 PM
