Flex Fuel testing in TephraXMOD V3
Old Jul 17, 2017, 03:52 PM
  #271
RazorLab's Avatar
Received 1,038 Likes on 760 Posts
Originally Posted by naelzm
im looking to purchase v3 for flexfuel options but looks like it doesnt support USDM EvoX MR 2012. any reason why its not supported? will it ever be supported in future? im guesing its a work in progress. tried to PM you but ur inbox full lol, hope to hear from you...
Use MR V3 for 2013-2015 or 2010
Old Jul 17, 2017, 03:59 PM
  #272
naelzm's Avatar
Do you know the difference if i where to use the 2013-2015 ? If they are the same why not include the 2012 is support list?
Old Jul 17, 2017, 04:05 PM
  #273
RazorLab's Avatar
The newest Ecuflash supports this type of flashing without having to bench flash.
Not sure about the differences. I can tell you I used a 2010 V3 on this 2011 MR with no issues:
https://www.evolutionm.net/forums/ev...-flexfuel.html
Old Jul 17, 2017, 04:08 PM
  #274
naelzm's Avatar
nice, good to know. Thanks
Old Jul 24, 2017, 10:46 AM
  #275
LOVEMYX's Avatar
Originally Posted by LOVEMYX
rolling antilag
Is this possible on stock ecu?
also would it be possible to run 8 injector setup off ecu flash???
Old Jan 11, 2018, 06:12 PM
  #276
Solarwater's Avatar
Hi, I am having issues with V3 flex fuel and hope someone can help. I am using the flex converter hardware kit.
The raw ADC and copy of raw ADC are matching the sensor output correctly, but the filtered value is not changing, and the ethanol percentage is clipped to 100% (which does not even match the filtered value I am reading)
See the chart below, the flexconverter kit is in cal mode, so it is stepping through 0,25,50,75,100%. You can see the filtered value is not moving at all.
Here are the labels that I believe are critical to get the ethanol% input working. Am I missing anything?
Does anyone have any insight?
I also see Tephra's documentation says there is a label for max load for signal processing. I do not see the label in ecuflash, unless it is combined with the alternate map load threshold?
Thanks
Old Jan 11, 2018, 07:13 PM
  #277
Solarwater's Avatar
Thanks
Well I posted a little too soon, lol.
Figured it out. I unplugged the ECU and waited a few seconds and reconnected, the values in the V filtered and ethanol % cleared.
Also, the filter does not run unless the fuel pump is running.
Maybe this will help someone else with a similar issue.
Old Jan 20, 2018, 08:08 AM
  #278
stigmeister's Avatar
Is anyone else experiencing issues while using NLTS & flex fuel? Tuner was unable to set it up properly on my car.
Old Jan 20, 2018, 04:51 PM
  #279
tephra's Avatar
hey Stig - its a know bug (Actually the only known bug) that NLTS and Flex dont play well together, the rev limit gets set incorrectly... im going to fix in V4 (if/when that gets released)
Old Apr 17, 2018, 07:19 AM
  #280
veszett's Avatar
Can someone please explain what happens when you try to use NLTS with Flex fuel, what the bug?
Old Jun 13, 2018, 04:50 AM
  #281
Poison_Snake's Avatar
Blessings i don't know if anyone can help me, i make my Lancer 2009 4b11 turbo about like a month ago, first up my tuner just took the oem ecu and replace the rom to evo x rom now my rpm idle is always on 2000 i hate my car lol and every tuner i ask said to me if my car doesn't have abs the speedometer and the tpms won't work, i don't know about tuning but there isn't a way to replace reading from the abs to reading from the speed sensor?
Old Aug 19, 2019, 12:29 PM
  #282
lobzik's Avatar
purchase TephraXMOD V3
Sorry, for the off top.
Hi, David aka Tephra,
I tried to reach you via private message, but your inbox overload))))) So, it's why I'm contacting you here.
My name is Roman Shovkun; I paid on Aug 15, 2019, for TephraXMOD V3 for my Mitsubishi Evo X.
The PayPal Transaction ID 7N583787N03108505, if needed I can send you the receipt.
Please let me know when I can expect to receive it or how I can get it?
Thank you!
Best Regards,
Roman Shovkun aka Lobzik
Kiev, Ukraine
email: rshovkun@gmail.com
cell: +380667854398
Skype: ramzesvelikiy
Old Aug 20, 2019, 03:56 AM
  #283
lobzik's Avatar
Thank you!
Best Regards,
Kyiv, Ukraine
cell: +380667854398
All, set!!!
David responded via email.
Thank you!
tephra
Sep 13, 2021 01:07 AM
tephra
Aug 11, 2019 09:05 AM
Lightsaber
Jul 30, 2015 07:57 PM
xirtam
Feb 12, 2014 09:27 AM
Quick Reply: Flex Fuel testing in TephraXMOD V3
