Speed Density Idle problem ( 70 LOAD- 10.5 AFR )
Old May 10, 2016, 01:45 AM
EvilEvolution8's Avatar
Hello Guys,
After 5 days my Evo 8 with speed density running!
Car running at idle with 70 LOAD(95Hz airflow) instead 30, and 10.5 AFR instead stoich.
What's wrong? Seems needs a sort of calibration MAP -> LOAD ?
Thanks
Old May 10, 2016, 05:22 AM
pisyakot's Avatar
maf load = sd load, check you calibration
Old May 10, 2016, 06:02 AM
This is my sd ve table.
Any suggestions?
Thanks
Attached Thumbnails Speed Density Idle problem ( 70 LOAD- 10.5 AFR )-immagine.png
Old May 10, 2016, 06:32 AM
Evo9_Dubai's Avatar
I am not a professional nor a tuner, although your RPM VE seems a bit rich on the idle.
Old May 10, 2016, 11:55 AM
ridenrunwv's Avatar
Just noticed that you said after 5 days like this was a problem that just came up after 5 days of running differently on the same tune? If that occurred you might have a mechanical issue.
Old May 10, 2016, 11:58 AM
Any suggestions?
Thanks
Ohh no sorry! 5 days to male a conversion...today is a first day that i run with SD
Old May 10, 2016, 12:01 PM
ridenrunwv's Avatar
Try RPM VE 500 to 2000 as 64, 67, 70, 75, 80 and see if that leans it out any.
Old May 10, 2016, 12:02 PM
What cams and injectors?
All stock at the moment .
Old May 10, 2016, 12:03 PM
ridenrunwv's Avatar
I was trying to edit posts because reading replies you made right as I posted so messed the order of posts up a bit.
Old May 10, 2016, 12:04 PM
Thanks a lot!! I will try!
Old May 10, 2016, 12:05 PM
In your opinion...the rest of RPM VE and the MAP VE is correct ?
Old May 10, 2016, 12:07 PM
ridenrunwv's Avatar
Can't really tell just by looking at that. You could honestly have all different variations of data in tables and the car still run fine.
Old May 10, 2016, 12:10 PM
Ok perfect!
Old Jun 22, 2017, 04:26 AM
K1LLACAM172's Avatar
Bump
im having a similar issue with my load, it's 44% at idle and the car uses mid LTFT at idle and sometimes goes to low, any ideas? Did raising your RPM ve tables a bit help as suggested?
Old Jun 22, 2017, 10:46 AM
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
Need to change the crossover points for your fuel trims. It shouldn't go to mid until like 55-60 load.
Quick Reply: Speed Density Idle problem ( 70 LOAD- 10.5 AFR )
