Logging AFR using innovate MTX-L wideband
Old May 7, 2017, 01:30 AM
eazlan's Avatar
Guys,
I need help..I just hooked up the mtxl brown wire to pin 73 ( mine is evo 8mr . With 3 plugs ecu ).
in evoscan , I'm logging the afr data by WBO2 . And the formula is as per stock..10.00 + ( 16.99-10.00 ) *X/255....but why is the reading in evoscan is not the same as meter reading?..different like...evoscan wbo2 read 10.1...but meter reads 14.9...need helps...is it the stock formula doesn't match and innovative need a formula to match it...
xPRimNT
157
Dec 26, 2018 08:09 AM
insmniac95
Sep 12, 2014 12:10 AM
EvoIVOwner
Aug 14, 2012 09:03 AM
adlpb
Aug 8, 2012 12:22 PM
evo jason
Jan 7, 2012 04:25 AM
Quick Reply: Logging AFR using innovate MTX-L wideband
