EVO IX 8859 comes out of open loop at idle
Old Feb 5, 2018, 05:03 AM
Project_Broke's Avatar
Hi all,
Something that is starting to get on my nerves, I am trying to run a lean idle and have all of the open loop load tables set to 0 in the idle areas.
When I start the car, it will idle at my target AFR, if I blip the throttle it will then idle back down and somehow go into closed loop and sit at 14.7. It will not go lean again until a reflash.
I had the idle where I wanted it for a few days with no changes, then this started happening for no reason, now I cannot get it to stay in open loop.
Any ideas?
Old Feb 5, 2018, 05:28 PM
CDrinkH2O's Avatar
The car starts in open loop and does not change to closed loop until the coolant temp hits 84 deg F. Open Loop Throttle #1 & 2 also need to be set to 0% at idle RPMs. The logic used for the transition to open loop is coolant temp > 84 deg F and either load or throttle exceeds the value in the respective open loop table.
Old Feb 5, 2018, 05:50 PM
You are correct. I have been confusing open/closed loop for some reason when looking at the throttle tables. I will switch them to 0.
Thank you.
silverstream
Oct 2, 2006 08:34 AM
Mad_SB
Jul 13, 2006 05:18 PM
04T-WRX
Lancer Engine Management / Tuning Forums
Mar 1, 2006 04:43 PM
hi_nrg_fizzix
Jan 16, 2005 07:53 PM
Quick Reply: EVO IX 8859 comes out of open loop at idle
