ceddy mod
ceddy mod
I've noticed with ceddy mod 5/6 the injectors are put down at 575cc is this going to cause a issue, also I'm not going to be using SD so if I turn that off it will just use the maf like normal? Copying my tune I have already done back into ceddy mod should be fine in the way my fuel maps etc so I don't have to retune everything correct?
CeddyMod_Evo56_1v20b is the one I have, also will the injectors being at 575 be a issue when they are usually 560?
http://ceddy.us/store/ceddymods-evo56-1v20/
Thats the maf version, and even though it shows SD functionality, it doesn't work. The rom ID for the SD one is 25570300, and the MAF one is 25570100.
Message me your email address and I'll send you the SD version. I was running the SD version for about 4 years and have just switched to a Link G4+.
thanks very much the SD will be handy in the future when I decide to change the turbo setup and then go SD, for now I just want to use the tune I've spent the past month perfecting but add ceddy mod for launch control etc, If i just copy all my timing maps and fuel maps into this will it be fine, also how do I go about using the dual maps on it? I couldn't find any information on it..
I noticed it wont let me set the injectors for 560 now so should I leave them set at the 575 the mod has them at?
It's 575 in Ceddy's due to the injector table definition in the rom which is inherited from DSM roms in Ceddy's. So, basically don't worry about it, it's the correct value for the stock injector.
sebas-chan
Apr 25, 2018 06:03 AM
