Speed Density 2.0 (3D VE Tables, Baro)
5 Attachment(s)
Updates:
Updated the IAT scaling for the all roms Well hasn't this been a long time coming? Current roms are still in testing and being debated Success in the patch for 3d VE maps however the persistant jitter bug still currently exists which I'm working on but likely will take a while to fix. Its more an annoyance than a real problem only happening on low loads cruising in certain situations which can if really needed driver choice avoided. It is assumed you have the xml's from the previous tephra v7 patches if not download them as marked here. Current Roms I plan to patch: 94171715 96531706 88591715 Notes: I've given up on the live tuning thing as I can't really grasp how the patch and the program sync up. Since it seems to be easily done by other people I'm going to leave it up to those experts to patch in live tuning. Testing nearly complete still need some more testing :) 9417 Variant: https://www.evolutionm.net/forums/at...d-94172715.bin https://www.evolutionm.net/forums/at...d-94172715.zip 9563 Variant: https://www.evolutionm.net/forums/at...d-96534706.bin https://www.evolutionm.net/forums/at...d-96534706.zip 8859 Variant Rom: https://www.evolutionm.net/forums/at...-tephramod.bin https://www.evolutionm.net/forums/at...d-88592715.zip XML Pack: http://www.norcalmotorsports.org/use...OD-XMLPack.zip https://www.evolutionm.net/forums/at...new-tables.jpg |
2 Attachment(s)
Clearly some people are having trouble grasping this relatively simple patch so i'll just draw it out for them picture are worth a thousand words right?
As you should be able to tell the Map volts vs kpa should always be 1:1 so you don't screw up the other table axis. What will happen is you'll measure 40kpa or something and it wont match to the point on the table because its not aligned. If you want to effect load you do that with the kPA vs Load table while this should have been obvious I guess its not. https://www.evolutionm.net/forums/at...1&d=1299136674 |
Roadspike you are the man!!!
Thanks for all your hard work!
Devin |
Great work, can't wait to put the car back together and test this out. I've managed just fine on 2D maps, but this should help dial things in perfectly {thumbup}
nice work roadspike! Been debating on making the switch to SD. Just reading for now, but the new VE table looks good, and has given me more incentive to really read up on it. {thumbup}
1 Attachment(s)
Great work. I would suggest a new number for these roms though to prevent xml issues as this will represent a fairly significant change in tuning method.
96534706 and 96535706 for non-live tune and live tune version, respectively? Also, as for an idea, I would highly suggest a slight break in the current methodology. Currently we try to make MAP pressure into Load using a xml scaling parameter that has to be adjusted depending on what MAP sensor you are using. This does a couple things all in one map. First, obviously it allows various map sensors to be used, however it requires changing xml settings to make it happen. Second, it allows rescaling for engine displacement to take place. For example, if you go up to a 2.4L, you can simply increase VE in this map by 20% and it will compensate for it. Third, you tune MAP based VE by it. My suggestion is break this map apart into separate functions. Use a MAP-Voltage table to program for different MAP sensors then there is no need to change xml scaling values depending on MAP sensor. This way, ANYBODY can simply take predetermined numbers for a given MAP sensor and plug them in and know that they will be in the ball park right away. Then include an engine displacement variable. Going from a 2.0L to a 2.4L? Simply type in 2.4 into the box and it is accounted for. The MAP VE is then taken care of completely in the 3D table. You could potentially do this for a fuel change as well. Putting in E85? Change this variable from 14.7 for gasoline to the appropriate AFR for stochiometric AFR of that fuel. This of course wouldn't change load, but you could use it as a nice little feature to adjust injector sizing. Here is what I wrote and how it looks. https://www.evolutionm.net/forums/8622723-post108.html The attachment is my code. I used the original MAP-VE table and the MAP calibration table. I used memory addresses 2F40 to 3300 to define my tables. |
Thats why i thought we should use map ve load as the axis that way its independent of the map sensor voltage and doesn't need to be rescaled each time its change.
oh Mr Roadspike, please make these sexy patches portable to other rom ids, i want eventually to have it in my 88580714 too :)
3D sd tuning
I am new to tuning the sd i have not yet done the sd conversion but will be doing so wit my fully built 2.1. How would u tune the 3D maps? kind of looks confusing.
You would bring your car to a professional tuner :P
Sorry for slacking on not testing the 9417 3D rom but Im waiting on my new iat to come in. The resistances to deg was off by alot from what it should be, Im thinking it wasnt a gm iat sensor. |
I guess i should hurry up and finish the latest iteration of the SD tuning patch too.
going to have 3 new tables replacing most of the patch First a calibration table for the sensor voltage to kPa/psi Secondly a kPa to Load table replacing the map volts to load as it is now Lastly kPa vs RPM for VE instead of load I figure if setup up right the only table that will really change is the sensor calibration table and all the rest of them will not. I'm also working in the SD auto tune for the patch almost finished really everything's done expect a couple tables relating kPa to baro pressure. Should help with mountain top startups. |
Originally Posted by RoadSpike
(Post 9081937)
Originally Posted by justastockevo
(Post 9054560)
(Post 9054560)
oh mr roadspike, please make these sexy patches portable to other rom ids, i want eventually to have it in my 88580714 too :)
