Need Help With Rims
Need Help With Rims
Hey guys, anyone of u know whether the Enkei Bortex RPM2 rims 18*8 with a +35mm offset would fit on a EVO6? I was wondering whether there would be enough clerance for those HUGE Brembo brakes?
Thanks!
Thanks!
Guest
Posts: n/a
Originally posted by BaNaNaCaR
Why wont they fit???
How do you know it wont fit?
Is it that there is not enough clearance for the brakes or what?
Should i get a different offset???
Guest
Posts: n/a
Thanks for laughing, it was indeed meant as some kind of a joke!
+30mm would be right. Otherwise, the wheel sits too far "inside" and the spokes could touch the caliper, as a lot of people find out when trying to fit the wheel to the car
It depends, however, on the wheel spoke design and it MIGHT fit with a bigger offset in some cases, ie where the spokes are "rounded" from the center to the rolling surface like the WRC Enkei wheel...
But anyway, this way you get a slightly bigger distance between the front (and rear) wheels...
BANANACAR !!!!!
I just ordered a set of the RPM2 's... i was told BY ENKEI that the only offset that fits the evo is on the 18x 9 !!!! AND YES, the B'GASSS calipers are the reason that the offset is SO critical ... HYPERBLACK. they'll be here in a week
OctaneX2
Jun 5, 2012 07:19 AM
