need help with install
Old Apr 17, 2009 | 07:06 PM
ryandude1's Avatar
i recently took my evo x to get a remote starter installed and the shop is having a problem getting it to work. it will only work with the ignition in the accessory position.i have the fast key option. does anybody know what the accessory position powers up? or what it does? i need to know this before install is complete. please help!
Old Apr 18, 2009 | 02:23 PM
MRCole's Avatar
Um, it won't work because it needs a bypass for the car to turn over...if you have that, then they didn't hook it up properly. If it cranks but doesn't turn over, could be not sensing chip...there are ton's of reasons why it's not working. Ask for a refund and take it somewhere else.
Old Apr 18, 2009 | 02:26 PM
GPTourer's Avatar
You're probably going to have to hide an extra key somewhere in the car so that the stock imobilizer/Fast key system thinks your in the car and allows it to crank.
Old Apr 18, 2009 | 08:34 PM
ryandude1's Avatar
it is a compustar remote start and a can-sl2 bus interface. they did hide a key in the car. the starter would work fine as long as the ignition was in the accessory position. if it was in the off position the car would not start.
Old Apr 18, 2009 | 09:39 PM
MRCole's Avatar
Does the car crank at all when you remote start it?
Old Apr 19, 2009 | 04:19 AM
ryandude1's Avatar
yes, it actually starts when the ignition is in the accessory position. when it is in the full off position it does nothing.
Old Apr 19, 2009 | 02:20 PM
MRCole's Avatar
Double check the antenna ring, double check they wired all the ignitions and accessories.
Old Apr 19, 2009 | 08:10 PM
ryandude1's Avatar
what accessories have to be wired? or i guess i should say "how"
Old Apr 20, 2009 | 01:41 AM
MRCole's Avatar
Don't have a wiring diagram on me atm, meter the wires to be certain. Soldier and tape.
dmik
Lancer Troubleshooting
12
Nov 20, 2021 09:12 PM
whitepwr
Feb 10, 2010 06:03 PM
johnjonfenomeno
13
Aug 11, 2008 11:20 AM
SLVROZ_03
13
Jul 28, 2007 11:35 AM
silverEVO8
Jun 9, 2003 09:39 AM
