Post Your Widest & Highest Torque Curves: Twin Scroll 35R (or equivalent)
Old Feb 23, 2009 | 12:30 AM
BoostLover99's Avatar
Nice!
Old Feb 23, 2009 | 07:44 AM
mostH8D's Avatar
the "N" is for Newtons which is a metric unit measuring force. torque normally described as Nm which is newton meters.
i did some looking into of tractive force but my resources were a bit limited. if anyone knows chime in. im kinda interested.
Old Feb 25, 2009 | 05:43 PM
David Buschur's Avatar
You have to find the car that belonged to Wazvette on here, I believe that is the best torque curve I have seen personally.
Old Feb 25, 2009 | 05:47 PM
Here's a good one of Nick's car:
https://www.evolutionm.net/forums/ev...-brs-dyno.html
Check out post #47 in that same thread
Old Feb 25, 2009 | 06:00 PM
Evolution IVGSR's Avatar
Originally Posted by big block ix
A LOT OF TORQUE small turbooo..
My car..
WOW What Turbo and mods to the car?
Old Feb 25, 2009 | 09:30 PM
Thanks a million, Dave.
That's the holy grail that I've been searching for.
From what I gather on the thread, it's a BR 67 P trim turbo kit with header on a BR 2.3L stroker.
Old Feb 25, 2009 | 09:40 PM
FQ4OO's Avatar
i should point out my chart showing 308kw is with the ecu tuned down as the fuel system is maxxed out and the mixtures were starting to go lean. Also the stock coil packs arnt giving to spark required so these parts are being changed then the car will be tuned to suit. Hoping for around 330kw and flatter torque curve on similar boost. Will post the new chart when the work is done.
Old Feb 26, 2009 | 12:52 AM
Solid - can't wait to see it.
Old Feb 26, 2009 | 01:15 AM
boostlover, yes that is a 2.3 liter engine with our single scroll T3 header and a .82 turbine housing.
Given all the testing I have done in the last year or so I think we could do even better. You have to get the cam, intake, turbo etc all right and have a customer who wants that one particular build.
The new project I am working on will have the Red on it but should have abolutely MASSIVE torque and when I switch to a larger turbo on it (if ever) that should carry over.
Old Feb 26, 2009 | 09:32 PM
Sounds awesome! Can't wait to see the graphs when you're done!
Old Feb 26, 2009 | 09:56 PM
big block ix's Avatar
Green E-85 and a 2.3L bottom end^
Old Aug 31, 2010 | 08:27 AM
SWOLN's Avatar
I'm just bumping this thread to see if anyone has made equal or better power curves in the last year and a half.
Old Aug 31, 2010 | 05:58 PM
94AWDcoupe's Avatar
Originally Posted by Ted B
I don't know. I do know he's broken a few trannies - not hard to understand why!
Basically, this illustrates what this TS setup can do. If one has a TS 4088R and isn't getting this type of power, it isn't the fault of the turbo.
he posted breaking sixteen trannies when the 4088 was on the car.
Old Aug 31, 2010 | 06:01 PM
94AWDcoupe's Avatar
http://www.lancerregister.com/attach...1&d=1259781865
Old Aug 31, 2010 | 07:13 PM
Steve93Talon's Avatar
I posted this on a BW thread awhile back, S362 in the .85 divided T3 hotside, full boost at 5k on a 2.0 liter DSM, 700+whp. This was on winter blend E70 with BC280 cams, JMF SMIM, ross/eagle 8.5:1 bottom end, full 3" exhaust, Garrett 3.8" FMIC with 2.5" piping and stock TB. Tuned on ECMlink.
