Stock FMIC dyno record?
Old Feb 18, 2009 | 07:55 PM
Tractionlimit's Avatar
Hello, is there a VIII / IX stock FMIC dyno record? I'm curious to see how much the stock FMIC restricts an upgraded turbo like the Red. Thanks.
Old Feb 18, 2009 | 08:15 PM
RyeLou's Avatar
I don't know what your intentions are, but I don't get "records" like what you're asking about and maxing out the stock turbo. By the time you're setting a record, because of all the heat involved its so inefficient it's not funny. Why not upgrade to the necessary part?
I just can't see myself spending 10K to get the stock turbo record as opposed to spending 10K and getting an easy 100hp more with a proper turbo set up.
Old Feb 18, 2009 | 08:19 PM
aka.ralliart15's Avatar
I dont think people focus on this kind of record that much...i mean the intercooler is a very important part of the whole turbo set-up and staying stock or getting an inferior one will seriously hurt you and most likely cause heat oversoaking....it would be best to upgrade if that is your question.
Old Feb 18, 2009 | 08:59 PM
dbsears's Avatar
If you can afford a Red don't be cheap and run the stock intercooler. Heatsoak and knock will be prone and bad things happen. Don't waste the time for a pointless record. Its like setting the record for who made the most power on 87oct
Old Feb 18, 2009 | 09:19 PM
JohnBradley's Avatar
11.54@118.7mph in a full weight 6 speed on a Green with a stock clutch and stock cams. Whats that maybe 400whp?
Old Feb 18, 2009 | 09:32 PM
JeffMas1587's Avatar
fp red with stock fmic made 470whp on a DLL. stock motor with gsc 272 cams. 93oct 30psi 100% meth
Old Feb 18, 2009 | 09:54 PM
DSM.org's horsepower calculator says somewhere between 431-437whp for that pass.
Old Feb 18, 2009 | 10:15 PM
N3VO's Avatar
if your going to be upgrading to a red upgrade the fmic too.
Old Feb 19, 2009 | 04:07 AM
4TUN8's Avatar
I trapped 119mph with the stock FMIC on pump gas about 2 years ago.
Old Feb 19, 2009 | 10:34 AM
BluEVOIX's Avatar
I guess a better question would be: At what point does the efficiency of the stock intercooler drop enough to put it higher on the list of mods to do?
Old Feb 19, 2009 | 10:38 AM
11secDSM's Avatar
I made 457whp through the stock FMIC.
Old Feb 19, 2009 | 10:45 AM
Sorry, maybe I should rephase this. I don't intend to challenge any records (I'm driving an X now anyway).
I'm only wondering what the actual limits of the stock IC are. FMICs seem to be the bread and butter of a lot of race shops, but I haven't seen a lot of tangible comparisons other than them saying I just need to go drop $1000+ for this and the associated piping. Also wondering if cold weather gives the same benefit on the stock IC. All that said, I'm sure I will end up buying one, but I like to see what my gains/$$ are for each mod. Thanks.
Old Feb 19, 2009 | 10:48 AM
Nice, what did it take to go from there to the 502 you have in your sig?
Old Feb 19, 2009 | 10:52 AM
Exactly. Said better than I could have myself.
Do I install and tune the Red i have sitting here now, or wait a while until I have enough extra cash to do the FMIC at the same time?
Old Feb 19, 2009 | 10:54 AM
11secDSM's Avatar
Swapped in a Garrett cored FMIC and a Brad Brooks tune.
