MAF help?
Old Mar 9, 2009 | 08:49 PM
mostH8D's Avatar
MAF help?
got my car tuned and early on in the revs i was maxing out the MAF.
appearantly the stocker clips at 380 (cfm?) and about 3500 rpm i was maxing it. the tuner tuned the car with this limitation never allowing it to clip so the end result was pretty low. with a 2.3l / 35r kit it only made 390/350.
he says he thinks its because there is a tiny air filter on the car and he'll try to fab up some pipes to allow a bigger filter.
any other ideas?
Old Mar 9, 2009 | 09:49 PM
SpoolnupTuning's Avatar
any other ideas?
Ive made over 500 on several cars with the stock maf. The intake may be a problem, but what kind of filter do you have on it and what kind of boost was it running?
Old Mar 10, 2009 | 08:24 AM
mostH8D's Avatar
18 psi (waste gate spring pressure) and its a COBB filter. the piping was replaced with custom stuff so its JUST the filter.
Old Mar 10, 2009 | 09:36 AM
EVOIXreno's Avatar
then where is your maf at?
NM... Could be your piping... what's the diameter of the custom piping
Old Mar 10, 2009 | 01:38 PM
well. what is it doing? if he is saying maxing out, does he mean running lean?
mrfred
91
Mar 20, 2011 12:10 PM
highpockets
23
May 10, 2010 09:22 PM
gizmotoy
Evo X Dyno Results
14
Aug 26, 2009 01:22 PM
06RS
26
Dec 20, 2008 10:32 AM
Trail Slide
Sep 22, 2008 09:28 PM
