Retuning FP Red @ CBRD
Old May 1, 2009 | 06:42 AM
griffeyr's Avatar
I will be @ CBRD next tuesday (May 5th) to have my GSC s1's installed and retuned along with some defi gauges....Wish me luck
Old May 1, 2009 | 06:48 AM
aka.ralliart15's Avatar
Nice good luck...you'll pick up some power.
Old May 1, 2009 | 08:05 AM
bustin's Avatar
What did you have before? Just stock 9 turbo?
GL
Old May 1, 2009 | 08:22 AM
CBRD's Avatar
he had a red before, tuned by another shop...
we are doing head studs, new gasket, defi gauges, pod, gsc cams, and a retune
cb
Old May 1, 2009 | 09:28 AM
griffeyr's Avatar
GL
like chad said, i had the red before....the power i previously made is in my signature, on a dynomite (which everyone says reads like a dynojet)....so after chad works his magic, i'm hoping to pick up quite a bit of power
Old May 1, 2009 | 09:42 AM
Tnnrx7's Avatar
Good luck bro can't wait to see what she puts down
Old May 1, 2009 | 10:13 AM
griffeyr's Avatar
thanks buddy...i'll post the dynosheet when i get back next week
Old May 1, 2009 | 10:27 AM
04WWRS's Avatar
You'll pick up power no doubt. It might not be reflected in the #'s though. Considering the two types dynos. All indications are that CBRD's will read a good bit lower. Cams may make up the difference. Just saying, don't worry if the #'s don't change much. You'll feel it.
Will you just be on pump gas?
Old May 1, 2009 | 10:41 AM
griffeyr's Avatar
yeah on 93
there were also other issues that caused the other tune to not read as high, even thought it was a dynojet....stock cams, only 23 psi, stock licp, and i had an exhaust leak
Old May 1, 2009 | 10:44 AM
DS-03evo's Avatar
Does your red have the new anti-surge cover? Good luck..post up the sheet then, you should make around 400!
Old May 1, 2009 | 11:03 AM
griffeyr's Avatar
no i got a red out of the first batch....thanks man, my goal is 400, then i quit for a while
Old May 1, 2009 | 11:30 AM
Evoluvin's Avatar
ill be calling chad in a few weeks for a tune
Old May 1, 2009 | 11:33 AM
04WWRS's Avatar
Originally Posted by griffeyr
yeah on 93
Cool. Good luck to you. Any plans for meth or dual maps so you can add c16 or something? Just so you can to the boost level where the red seems to work best.
Old May 1, 2009 | 12:36 PM
Noize's Avatar
EvoM Administrator
griffeyr-
When you have a graph, edit the first post and I'll move to dyno results thread. Thanks!
Old May 2, 2009 | 06:39 AM
CBRD's Avatar
I have a feeling we will exceed the power numbers by a bit, even considering the different dynos.
cheers
cb
