Buschur Tuned- FP RED on 93
First, I would like to thank Dan for the hard work!!! "Damn AC". As the title states I had Buschur install Fp Red,1200cc,Ported manifold and HKS DLi and a Great Tune from David. All the parts below where already installed by J.Weaver who also built the engine if you don't know him you should
and previous tune was from AMS who also have done great job with my MR. The previous numbers are in my signature was on Cam #2 on 28psi, This tune we decided to go with a 93 instead of E-85 because its my daily driver most of the time and not always friendy low mph driving and locations of E-85 advised from Dan. Also I'm not 100% sure on the the PSI for the current numbers will update later. I will be at Buschur Sport Compact Nat's for its first run with the new parts Im hoping for 10's with the stock 6spd ! ! !
2.0 bored .040 over
Wiseco Pistons
Pauter rods
arp rod/main bolts
HKS 272 cams
HKS cam gears
arp head studs
Ferrea 1mm over sized valves, dual springs, ti retainers
custom bronze valve guides
mild port/polish
HKS head gasket
JAM lifters
Rallysport thermostat
greddy timing belt
AMS balance shaft eliminator kit
rotating assembly balanced
perrin crank pulley
exedy twin disc HD cerimetalic clutch
AEM EMS
AMS VSR intake manifold
AMS fuel rail
BBK 75mm TB
Walboro 255lph pump
AMS upper and lower intercooler pipes
AMS intercooler
Tial BOV
ARC catch can
AMS small battery kit
DC sports 3" downpipe (no cat)
Greddy 80mm titanium exhaust
NEW NUMBERS 449 HP AND 401 TQ "BUSCHUR DYNO ON 93" 24PSI
OLD NUMBERS 380 HP AND 401 TQ "AMS DYNO ON CAM#2" 28PSI
2.0 bored .040 over
Wiseco Pistons
Pauter rods
arp rod/main bolts
HKS 272 cams
HKS cam gears
arp head studs
mild port/polish
HKS head gasket
JAM lifters
greddy timing belt
perrin crank pulley
AEM EMS
AMS fuel rail
BBK 75mm TB
Walboro 255lph pump
AMS intercooler
Tial BOV
ARC catch can
