FP White 2.3L 458.7awhp/476.58tq
2.3L + small turbo= fast on the highway too!
I did a "comparison" with my friend and Tuner on the highway...
His Evo also on E-85 with a 35R (25psi single walbro limited) 509whp/424tq
3rd gear both cars= pulled 3/4 of a car then he caught up to about my door.
Again with the Stroker in 4th gear his car in 3rd gear= even until he shifted into fourth and fell a little behind.
^^The trick is to run maybe -1 degrees of timing for a brief moment at spool up...
I am running STOCK ECU boost control and a 65mm throttle body
The torque was near 455tq until I did some research and got advice from this forum..
One re-tune later it jumped to 506TQ same set-up
Even noticably faster then my previous 475TQ race gas tune..
nice numbers! I just installed a White, got a couple things to finish up and then its off to get tuned. Ill be running a 100oct map, no E85 around here. Looking forward to seeing some good results from this turbo!
