470whp TTP Tuned NEW EvoRed 80mm cover results inside!
Old Jun 9, 2009, 12:53 PM
TTP Engineering's Avatar
Carlos is no stranger to TTP. We have been working with him for the past few years. Upgrading, maintaining, tuning his 2006 Evo IX MR. His graphite MR has been tearing up the streets of Tampa, FL for quite some time.
This time around he came to us with a different setup to have tuned. Carlos was one of the first to receive the new FPRed with 80mm compressor cover. Some of the other notable changes he made to his setup was the addition of a custom fabricated exhaust manifold of the twinscroll variety. The workmanship appeared to be of good quality. Upon drilling and tapping the exhaust manifold, the runner walls were nice and thick, a good indicator of strength. Carlos also added a SzabaFab non-cdi coil on plug ignition system which was of very high quality. In the process of getting the car ready for the tuning, we added PTE 1250cc injectors and Aeromotive Fuel Pressure Regulator on a Perrin fuel rail.
Carlos wanted two maps designed for his car. The first was a pumpgas 93 map designed for everyday use. The second map he wanted for high boost and racefuel to terrorize the streets with. We first started with the 93 mapping on 1250cc PTE injectors which we dialed in quickly.
Here are the results for pumpgas 93:
After the pumpgas 93 tune, we added 5gal of Sunoco 116 and turned the wick up on the boost controller. Forge UNOS light spring was maxed shortly thereafter. Carlos did not want to exceed 35psi peak and the light spring in the Forge UNOS maxed out at about 34psi so we gave him the option to keep it the way it was or to move up to the heavy spring. Carlos opted to keep the car where it was at so he could enjoy a reliable 470whp.
Here are the numbers for the Sunoco 116:
And the overlay graph of 27psi on 93 to 34psi on 116 is here:
Old Jun 9, 2009, 06:21 PM
R/TErnie's Avatar
Can you show a boost plot as well?
Old Jun 9, 2009, 06:27 PM
localtoys73's Avatar
ahh i thought i would be the first to be tuned with the new 80mm o well ill be there soon scott hopefully
Old Jun 9, 2009, 06:36 PM
surferjeff's Avatar
Let me know when you are going. I want to watch!
Old Jun 9, 2009, 06:38 PM
^^will do should have the last of the parts needed by friday
Old Jun 9, 2009, 07:44 PM
SHhhhh's Avatar
Great numbers! Is that the Injen intake I see with the new compressor housing? Just a different coupler?
Old Jun 9, 2009, 07:57 PM
Yes Injen intake pipe with FP coupler.
Old Jun 10, 2009, 12:39 AM
Evostacio's Avatar
i need a red but i wanna get in the 440 or higher range
Old Jun 10, 2009, 07:43 AM
R/TErnie's Avatar
boost plot please!
Old Jun 12, 2009, 10:22 PM
shuttlegoose's Avatar
i would love to know the mods of this car... please update!!!!
Old Jun 22, 2009, 06:12 AM
We will be testing another 80mm cover this week so we should be able to have enough test subjects available to form a conclusive opinion on the new Red. At this point in time we are still testing them.
Old Jun 22, 2009, 07:24 PM
SHhhhh's Avatar
Good to hear. Anxious to see your findings.
Old Jun 22, 2009, 07:57 PM
Personally I think you are an HTA82 candidate.
Old Jun 22, 2009, 08:04 PM
SHhhhh's Avatar
You sure about that? lol
Old Jun 23, 2009, 05:58 AM
9600baud's Avatar
very nice thanks for sharing!
Quick Reply: 470whp TTP Tuned NEW EvoRed 80mm cover results inside!
