578hp/420tq @ 22psi
Old Jun 11, 2009 | 07:46 AM
mixmastermatt's Avatar
Old Jun 11, 2009 | 07:50 AM
Originally Posted by JuniorAWD
Can you take a picture of that same run, but hit the space bar so the CF shows up?
Anything else? I'm not bull****ting anyone here. I know dyno numbers don't really mean **** other than a way to measure changes. In fact, I'll post up the camparo runs from my highest stock turbo dyno run with this one to show the changes.
Old Jun 11, 2009 | 07:53 AM
Old Jun 11, 2009 | 01:34 PM
kouzman's Avatar
With so much power this car should trap 130+ mph easily. Are you guys hitting the track any time soon?
Old Jun 11, 2009 | 04:08 PM
JuniorAWD's Avatar
Matt, the only thing I have doubts about is the boost.
Congrats on the numbers man, and way to man up and show the CF. Even if its more boost then it shows, that car should be a mid 130mph car!!
Junior
Old Jun 11, 2009 | 07:03 PM
k2boarder3187's Avatar
Junior
Exactly, cars making big power at such low boost....
Old Jun 11, 2009 | 07:36 PM
Dave@TTP's Avatar
LOL at the Description on the dyno sheet.
Old Jun 11, 2009 | 07:58 PM
Junior
I don't know what to tell you guys. Keep in mind, I have a lot of stuff to optimize airflow: a 2.3ltr block, 4" unrestricted intake, 2.5" IC piping, 75mm TB, SMIM, Buschur stage 3 ported head, full buschur turboback exhaust. Perhaps my setup just allows for a higher airflow at lower pressures. When I get it back on the dyno, I can take pictures of my ZT-2 display, Labonte display, the dyno display and I'll even post the evoscan logs off the JDM 3bar MAP sensor. I'm not trying to con anyone, I have absolutely no reason to.
Old Jun 11, 2009 | 08:25 PM
TTP Engineering's Avatar
95ft lbs far exceeds the specs on ARP standard headstuds.
Old Jun 11, 2009 | 08:33 PM
You're right Scott, which is why I refused to do what Dave suggested and had the o-rings removed. Every time I installed the head, I torqued to 85 ftlbs, per ARP sepcs when using motor oil for the lubricant. An additional 10 lbs would not have helped the headgasket seal any better and would have possibly led to stud failure. As for the torque wrench being out of cal, after Dave said the wrench was probably off calibration, I took it to the cal lab at the Navy base I work on and had them check the cal specs. It was within .05% @ 150ft lbs. At this point, I'm just glad the car is running correctly and doing better than I expected, despite the naysayers and nutswingers.
Old Jun 11, 2009 | 08:58 PM
dsevo's Avatar
I thought o-rings were supposed to be like .006in. .020 seems like a lot. Sick numbers though.
Old Jun 12, 2009 | 06:22 AM
From the research I did, the general consensus is the o-rings should protrude no more than 25% of the total gasket thickness:
Recommended O-ring protrusion is not more than 25 percent gasket thickness. Example: Gasket thickness .043˝, O-ring protrusion height is .008˝ to .010˝. This standard works with all thicknesses that are .050˝ and less. Gaskets that are thicker than .050˝ do not require ring height more than .012˝.
If I use a 1.2mm (.047") head gasket, then recommended o-ring protrusion should be no more than .012"
Old Jun 12, 2009 | 06:36 AM
Freddy302's Avatar
Originally Posted by batty200
587/1.12=525 so that is the uncorrected #'s. SAE asserts that if the correction factor is above 3% it should be ignored and it is NOT to be used to compensate for altitude either. Good numbers either way.
Wow these are very impressive #'s! with 525 uncorrected on a DD my car runs around 136-138 mph in the quarter mile at 3400 lbs. If you do that with 22psi.. you have found the best combo to date for the evo! your gonna have a line out the door..
Good luck with the car
Old Jun 12, 2009 | 09:37 AM
jid2's Avatar
Glad your car is treating you right. The green didn't last long
Are you using the new speed density patch?
Old Jun 12, 2009 | 11:05 AM
I never even ran it with the green, lol. A deal too good to pass up came along for the FS635 kit, so I decided to go with it.
I'm still using the speed density patch that Bez wrote for me back in the summer of 2007. I tried briefly to convert to John's s/d patch, but the car wouldn't stay running with it, so I switched back.
