Tomei Arms Pump Gas Results!!!!
its about time you got your tomei! first round numbers are good, get it fixed up and well see what that turbo can really make. the guy that bought mine just made 420 on pump at 24 psi, so you should have no problem getting it up there. its too bad you dont have e85 up there, then you can really see what this turbo can do.
I got mine in today...I noticed the hotside casting looks different that the OEM one. When I put the mani/turbo gasket over it they matched almost perfect. It is a bit rough but nothing a dremel can't handle. I remember when I ported my stock 10.5 i had to grind a lot.
Are u planning on hitting the dyno.
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Wow that is very impressive numbers. I guess that with the exhaust valves fixed you will be making so much more power.
Boost on Hommie!
Boost on Hommie!
o man i finally found this thread i wanted to see results on this turbo....seems like you had some bad luck though, but none the less that's amazing power with a failure...keep us updated please I want to see the final numbers....thanks
No prob I'll keep everyone up to date....I'm dropping my car off soon to get everything fixed.
Update: so my valve problems might be getting fixed soon, hopefully....it might take a little bit longer though, I have a surprise for you guys and i want to test it out after the head is fixed, I believe "It" will be a great combo with the Tomei Arms. I'm excited already lol
No I've got the one that looks like it but its not made with the same process...i really wouldn't be able to tell you how it performs but the runners are definitely bigger.
