574whp Stock block 92 octane 3586
Old Jun 27, 2009 | 09:47 PM
  #31
JohnBradley's Avatar
The most we have personally got out of a Red as of now is 544whp at 31psi. We arent trying to push that one too much past that though as it is a circuit car and the idea was longevity more than peak power. That car is a built version of my current setup with a ported head (IX at that), Red, and E85. If we went for all out I think it might be able to make more but I am not sure how much.
Old Jun 27, 2009 | 09:56 PM
  #32
Motoxrider7's Avatar
Alright. I wouuld really like to get 650 hp with my car. i am in the process of building a 2L. im not sure what turbo to get tho to get to my goal. I just like the spool up on the Red.
Old Jun 28, 2009 | 10:39 AM
  #33
impavidoevo5's Avatar
wow impressive numbers on 92 junk gas!!
Old Jun 28, 2009 | 11:06 AM
  #34
bambooi's Avatar
What is your timing at peak and redline? Also have you ran at the track yet? I have read some post where you have raced at the track before on the green, but nothing lately.
Old Jun 28, 2009 | 12:27 PM
  #35
04AWDTURBOEVO's Avatar
Amazing numbers from your set-up .
One thing I wonder is how the car feels on every day driving!
It looks like there is alot of lag.
Old Jun 29, 2009 | 09:01 AM
  #36
Timing is 1-2* at peak torque and 13* out the top. After the last trip with the Green last september I hurt the twin. The car would drive on the street but slip on the NLTS. We took it out with the twin anyway and finished it off. The clutch slipped a little on the 2-3 and alot on the 3-4. It still ran 123.5 at 25-26psi since we have to crank the MBC up at the track to get the boost right again. Its a good reason to get an EBC I guess
I have also been racing my 1G auto alot lately so the Evo has been a dyno queen for a bit but I'll take it back out before the built motor goes in.
Old Jun 29, 2009 | 02:46 PM
  #37
03whitegsr's Avatar
Originally Posted by JohnBradley
I am not going to go into all the specifics of where and why I think rod bolts fail, but I think 400 ft lbs is not their failure point. It seems its a little higher and typically its because cars are tuned with a big spike in mind which generates tremendous cylinder pressure at low rpm/high load (think stalling force). High revving engines with lower torque survive longer because the load is more gradually applied. I liken it to nitrous shock in a motor, the sudden increase in cylinder pressure can take rod material to the limits of its strength, hit elasticity, then fail. In addition to this is the "normal" tune approach that assumes timing is the most important thing we can do for power and not keeping in mind the direct relation to cylinder pressure.
You feel that cylinder pressure is going to be the likely source of failure of rod bolts comapred to engine speed?
Keeping a rod from folding by keeping peak cylinder pressure lower has been something that has proven to work very well. It's always seemed that RPM has lead to most stock fastener failures though.
Old Jun 29, 2009 | 04:27 PM
  #38
Originally Posted by 03whitegsr
You feel that cylinder pressure is going to be the likely source of failure of rod bolts compared to engine speed?
Well to a point yes, but RPM will still be the ultimate cause of failure (look at ARP's site for an interesting chart- http://www.arp-bolts.com/Tech/Tech.html). Its exponential based on reciprocating mass acceleration. This being said I wouldnt wind a stock motor too far past 8400 and even then occasionally. I have revved my motor this way for most of its life and routinely to 8k. Above 8k has always typically been track only.
Old Jun 29, 2009 | 06:57 PM
  #39
CO_VR4's Avatar
Rod bolts don't fail from compressive loads, like cylinder pressure.
They fail from the force of high rpm during the portion of the stroke when that force is unopposed by cylinder pressure.
Old Jun 30, 2009 | 10:04 AM
  #40
Carlyle's Avatar
Nice info guys, keep it coming
Old Jul 15, 2009 | 04:21 PM
  #41
I dyno'd one of our customers cars with the exact same setup, albeit with a built bottom end and ported head. The car is an VIII to my IX but came up with the same exact power numbers when it hit the wall on 92 octane. Jesse' made 574 and went on to make 576. The car also runs 131mph. Once its caged Jesse can get a little more comfortable with it and run better than an 11.4.
Old Jul 16, 2009 | 11:09 AM
  #42
evoracingstar's Avatar
put down some good numbers man!!
Old Jul 16, 2009 | 01:32 PM
  #43
kouzman's Avatar
So from that power level on a full weight car we are looking at 130-131mph traps, right?
Old Jul 16, 2009 | 06:02 PM
  #44
evo821's Avatar
very nice...impressive
Old Jul 17, 2009 | 07:39 PM
  #45
R/TErnie's Avatar
You mean they fail from a tensile load...on maybe like the intake stroke. :P
