494whp & 480wtq at 22psi on pump
Old Jul 13, 2009 | 01:54 PM
MR_3935's Avatar
Tuned on a Mustang dyno by our shop. We built the car for HPDE/ NASA TT so there is no Hi boost or Hi RPMs.
Basics: AMS 2.3 stroker
custom 86 mm pistons
JDM head (minor port and cleaning)
BC 280 ( they have to be degree'd)
Ferrea valve springs and retainers (stock valves)
stock U.S. intake manifold
Full-Race TS35R kit, FMIC
Prec Eng. 880cc
BLE solid lifters
thats the basics
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
the first chart is 17.5 psi and the second is at 22 psi. The car is tuned for track so we did not go for peak numbers or high boost. The car makes so much power and torque so early and pulls all the way to 7400 (off the dyno chart)...
Old Jul 13, 2009 | 02:11 PM
vaflyboi757's Avatar
dats fire bro, congratz
Old Jul 13, 2009 | 08:14 PM
danameisoj's Avatar
holy fast spool batman! very nice!
Old Jul 13, 2009 | 08:28 PM
rogue's Avatar
Damn that is nice. Is the gray line your AFR? Why does it looks like that
Old Jul 14, 2009 | 06:44 AM
MR_3935's Avatar
We installed a sniffer in the tailpipe just for the dyno to compare to our wideband. It read close but not as smooth due to it being in the tail end of the exhaust. Our AFR is roughly 11.2-11.3 at peak torque and goes to 11.5-11.6 all the way to redline.
Old Jul 14, 2009 | 07:24 AM
Philthy748's Avatar
Holy freaking boost threshold and power band! Congrats!
Old Jul 14, 2009 | 09:53 AM
EVO(boss)'s Avatar
wow really sooooo nice bro ....
I hope to get like your numbers sooooon
Old Jul 14, 2009 | 10:07 AM
ldstang50's Avatar
nice work...peak numbers are just that, peak numbers.
nice curve with very little taper and it doesn't look like it 'hits'
Old Jul 14, 2009 | 02:19 PM
Evolved_6's Avatar
hot damn thats some good numbers for 22psi. Im doing a similar build except the stroker is manley hbeam plus with wiseco pistons n kelford cams with a skunk 2 im. What housing did you go with on the 35r n is it a t4?
Old Jul 14, 2009 | 02:45 PM
SWOLN's Avatar
Wow! That's a nice graph.
Old Jul 14, 2009 | 03:26 PM
MR_3935's Avatar
Yes its a t4 TS. Our kit has the upgraded Oliver rods, our custom 86 mm HD Wiseco pistons. Thats the only difference between ours and the standard AMS 2.3..... The BC 280 cams we are running I think dont get enough credit-- but you have to degree them, they were 7* and 5* off what they wanted when straight up.
Old Jul 14, 2009 | 03:30 PM
Turbo Kyle's Avatar
Awesome, imagine if it had an HTA compressor wheel
Old Jul 20, 2009 | 02:11 PM
EriCS's Avatar
That car must be a blast to drive! How does it pull???
Old Jul 21, 2009 | 08:36 PM
vboy425's Avatar
nice powerband.
Old Jul 22, 2009 | 06:34 AM
gkania's Avatar
That dyno has always read really high. I remember Jose's stock turbo Evo put out like 480whp on it.
