BR HTA3586 @ 558.9HP Stock Block
Old Jul 18, 2009 | 05:35 PM
magyar86's Avatar
guys, did you miss the fact that he is running meth??? i have put down 551whp with 720cc denso injectors with stock fuel pressure and meth injecton with a M14 nozzle spraying 100% meth. so dont doubt the man people! geez
Old Jul 18, 2009 | 06:47 PM
JohnBradley's Avatar
Its amazing how much fuel an M10 or M15 will add. Realistically add the value/4 to the current injector size to see what is really going on. Methanol is less dense of course but it still allows you to visual a value for comparison.
Congrats on the power. The 3586 is definitely no joke for making nice power at "low" boost.
Old Jul 18, 2009 | 07:40 PM
R/TErnie's Avatar
Missed the bit about methanol. :P makes sense.
Old Jul 18, 2009 | 08:34 PM
kouzman's Avatar
Lol me too!
I am more of a straight pump or racegas type of guy!
Old Jul 19, 2009 | 12:54 AM
vboy425's Avatar
Old Jul 19, 2009 | 06:06 AM
recompile's Avatar
Hmm, as someone who's considering an HTA3586 in the future, I'm disappointed by the fact that peak torque is at 6300RPM. That's a lot of lag
Old Jul 19, 2009 | 07:33 AM
k2boarder3187's Avatar
Very nice. Car is making sick numbers on the stock ecu!!, Junior and Jimmy always do good work!!
Old Jul 19, 2009 | 07:36 AM
kouzman's Avatar
Well we are dealing with a turbo that has a 800awhp power ability on a fully built and prepped motor. It's definitely not an autocross setup but a strip/highway mega monster!
With the similar turbo 6262 I have seen cars hitting 105-108 on the 1/8 on pump easily! That's what this turbo is about!
Old Jul 19, 2009 | 09:29 AM
SparkTech's Avatar
Originally Posted by apotheosis
Yes stock ECU
I need to clean up the wires.
Nice to see the non-cdi cop lighting off the mixture. You don't have anything to worry about it was recently tested to 771whp without any issues.
Congrats that's a lot of power on a stock block
Old Jul 19, 2009 | 10:49 AM
scheides's Avatar
EvoM Moderator
Originally Posted by R/TErnie
800cc injectors making 560whp? I don't know about that. What was your base fuel pressure set at? Seems like you're making closer to 460 than 560.
1.2 CF! Do the math, that's 460
This is very true. I was running my stock injectors on my VIII up to 128% w/ an IX turbo spiking to 28psi with the addition of a 1.0mm aquamist jet (~450cc of meth) I had just enough fuel
I'm with you...top-end is pretty amazing holding power all the way, but the numbers are a bit dissapointing...My BBK@30psi on pump/meth put down 430whp on dyno dynamics (1.0CF...that's 515whp with a 1.2CF) and did it almost 2000rpms sooner than this setup. Unless you rev the **** out of it this seems like a laggy, laggy setup for the power it put down. Like I said above though, only HKS 272's....A set of kelfords and some valve springs would prolly do wonders for this setup. How aggressive is the tune? How much timing is it running at ~7500?
Old Jul 19, 2009 | 01:03 PM
R/TErnie's Avatar
scheides,
I see there to be no reason why they should be using a CF of 1.2. They're not in 150 degree ambient temps and they certainly aren't at 2k feet.
Old Jul 19, 2009 | 01:09 PM
denny424's Avatar
Inflated numbers brings in more customers!
Old Jul 19, 2009 | 01:14 PM
R/TErnie's Avatar
June 23rd 2009
Weather for 06850
High Temp: 75.7F
Low Temp: 66F
Average Temp: 69.2F
Altitude at "The Shop" 150 feet (at best)
Nice CF.
Old Jul 19, 2009 | 01:38 PM
Honestly they arent that laggy. The word lag in and of itself kind of is antiquated. LAG is what a french fighter with a Renault turbo motor experienced back in WWI. This is low power to 4500 or so and then its gone. In car and on the street it doesnt really feel like it looks on the chart. Stay a gear lower and rev to 8k and the power is all you crave.
Old Jul 19, 2009 | 02:55 PM
scheides's Avatar
EvoM Moderator
scheides,
I completely agree.
it's supposed to be a dynojet compensation but it's a bit overzealous. Dyno dynamics dunks are so consistent, everyone should just use 1.0 IMHO.
high boost threshold then. Call it what you want but this car has no torque under 6000rpm. I've driven a 35r car, I know it's fun, but for a dd street car the powerband just isn't wide enough (IMHO) unless you really rev it out...and I like my stock block
