Long Rod 2.2L HTA3582R Twin Scroll
I think there is way too much boost taper on the E85 graph, and the car would have an even better looking power/torque curve if I could take care of that. I originally planed on Ecu boost control, but my tuner talked me out of it in favor of dual MBC's, and I'm not sure it was the right choice. 3psi of taper in the higher rpm's would probably make the graph quite a bit flatter.
That boost profile is pretty good; 2.2l and twinscroll make for a responsive setup. I'm not seeing 20psi until ~4500 rpm and 30psi until ~5000rpm on a 2L single scroll. Might be time to upgrade the valve to avoid the boost taper up top. Good luck , look forward to seeing more results
Yes it will, but it gives up spool. Unless you're running 40psi, I don't think the gains warrant the loss of spool. If the 82 keeps gaining 25 hp/psi that means another 6 psi will put me around 700whp. Thats a lot of power for a street car.
