Long Rod 2.2L HTA3582R Twin Scroll
Old Aug 7, 2009 | 02:54 PM
  #31
dsevo's Avatar
I just got her back together, and all I can say is damn she is fun to drive. I have it set at somewhere around 22 psi right now, so I can't imagine how 28 psi feels. First gear is useless. I would like to log boost, and I have an OMNI 4 bar map sensor, but I don't think it is setup yet. Is there a how-to on setting it up so that I can show you guys some boost logs?
Old Aug 7, 2009 | 05:58 PM
  #32
dsevo's Avatar
I tried figuring out the settings in Ecuflash for the omni 4 bar map sensor, but I can't get it to work. When I try to log boost it just read 37.xx psi all the time and it never changes. I followed the instruction in the thread in the Ecuflash forum, but obviously I screwed something up.
Old Aug 7, 2009 | 07:44 PM
  #33
BLKCarbonEVO's Avatar
Originally Posted by dsevo
By valve do you mean the diverter valve? If so, I will crush it first and do before and after logs to see if that is the issue.
Yes it will, but it gives up spool. Unless you're running 40psi, I don't think the gains warrant the loss of spool. If the 82 keeps gaining 25 hp/psi that means another 6 psi will put me around 700whp. Thats a lot of power for a street car.
+1 and great build
Old Aug 7, 2009 | 08:59 PM
  #34
bambooi's Avatar
Search for jon bradley's post. english racing sells them and he posted all the info you need.
Old Aug 8, 2009 | 06:44 AM
  #35
Creamo3's Avatar
You may have one of the sensors where you have to flip flop the MAP sensor wires; I had the same issue w/ my 4-Bar. You can read up about it here: https://www.evolutionm.net/forums/ec...-settings.html
Old Aug 8, 2009 | 07:22 AM
  #36
EVOlutionary's Avatar
1 bar. The MBC's aren't even close to fully turned in, so I don't think that is an issue. I am running a metal OEM diverter valve though, I wonder if that could be leaking.
In the dyno testing I've done - the metal stock BOV started leaking around 23psi. You get the turbo to blow more psi that that - but part of your air charge is getting recirculated rather than going straight into the motor. . .
We picked up 40ft# at the torque spike by switching from the stock BOV to a Forge unit that did not leak at all. . . NO other changes at all. Boost went up from 28psi spike to 32psi spike without touching the boost controller or tune. . .
Old Aug 8, 2009 | 08:38 AM
  #37
dsevo's Avatar
Nice! I bet that's it. I've had the sensor sitting around for a couple months, so I probably got one of the bad ones. I searched, but I only typed in "Omni" and that thread didn't show up. Thanks again.
Old Aug 8, 2009 | 01:45 PM
  #38
dsevo's Avatar
Thanks Creamo3, that was the issue. I haven't gone out and driven yet, but it seems right at idle.
Old Aug 9, 2009 | 11:39 AM
  #39
SLVRNBLK's Avatar
Veteran: ArmyFCOTM Winner
Very nice set-up. Sounds great too
Old Aug 9, 2009 | 12:31 PM
  #40
dsevo's Avatar
Thanks Oz, it was nice to meet you. I spend a lot of time in my garage, feel free to drop by any time.
Old Aug 9, 2009 | 01:06 PM
  #41
project_skyline's Avatar
Get the APS twin vent bov, hands down the best for stock ecu and holds 40 psi solid!
Did you get the omni 4 bar MAP sensor setup? Bet the car is a blast!
Old Aug 9, 2009 | 01:17 PM
  #42
dsevo's Avatar
I will buy a new BOV, just not sure when. Yes I did get the MAP sensor working. I am running low boost right now, so it only shows 20psi at 4k rpm, but when I crank up the boost again I will be sure to log.
Old Oct 28, 2009 | 08:47 AM
  #43
NitrousOxide's Avatar
Synapse synchronic BOV the the best currently.. No doubt about it!
Old Nov 8, 2009 | 08:31 PM
  #44
EVO-EVO-EVO's Avatar
Question Anything new lately?
How is your Motor doing and what are the latest changes you have made to it?
Bob -
Old Nov 9, 2009 | 09:26 PM
  #45
R/TErnie's Avatar
I just made the switch to the synchronic... amazing.
I had the stock 9 dv
Crushed 9 dv
gus M modded and crushed 9 dv
TiAL 50mm valve VTA
and now the syncronic... best decision every.
Your stock bov is leaking undoubtedly... mine leaked TERRIBLY when I got the Red! I had to rescale my injectors during the retune it was leaking so bad.
