Help me reach my goal
Old Aug 12, 2009 | 02:28 PM
Blitz's Avatar
I am planning my next round of mods. I would be very happy if I could hit 375 whp on 93 octane and 425 whp on 110 on Buschur's Mustang dyno, as that's where I want to get tuned.
The planned mods so far are:
- BBK Full
- o2 housing or MAP o2 dump (undecided)
- DC Sports downpipe/cat delete
- GReddy Ti catback
- ETS 3.5" FMIC with 2.5" upper and lower piping
- Kelford 272/272 cams
- GSC Beehive springs
- ARP headstuds
- AEM TruBoost boost controller
- 880cc injectors
- Perrin air filter
- Walbro 255 fuel pump
- Tuned by Buschur
Do you think I'll reach my goal? If not, what should I change/add?
Old Aug 12, 2009 | 02:34 PM
5LEEPERISAH23I's Avatar
i think u might hit it... Make sure you have a 255 fuel pump
Old Aug 12, 2009 | 02:36 PM
Blitz's Avatar
Forgot that! Thanks.
Old Aug 12, 2009 | 04:15 PM
wtbEVO9's Avatar
Should be able to depending on how much boost and timing you run.
Old Aug 12, 2009 | 06:23 PM
Wht9er's Avatar
you will probably reach your goal. i would just go with the new green if i were you.
Old Aug 13, 2009 | 07:29 AM
godnf8's Avatar
A FP Red will get you there no problems with that setup. I'd suggest larger injectors and going E85 though.
Old Aug 13, 2009 | 07:41 AM
griffeyr's Avatar
+1, if u can get it in ur area.....won't have to change maps then
id say with that setup, you'll be close to 400 whp on daves dyno just on 93 pump
Old Aug 13, 2009 | 08:21 AM
DenverEvo's Avatar
+1 for bigger injectors & E85.
Old Aug 13, 2009 | 11:14 AM
Blitz's Avatar
I'm still looking at the Red but I intend to autox the car and REALLY don't want to sacrifice spool unless I absolutely have to. I am under the impression that the BBK Full spools like stock. Is this correct? And the Red would spool maybe 500-1000 rpm later?
For E85, how big injectors are we talking and would the Walbro be enough? Wouldn't I need a double pumper?
Old Aug 13, 2009 | 12:39 PM
DenverEvo's Avatar
You can run E85 on 880's. 1000's or 1200's would help support future mods. I am running E85 on a single Walbro......but it all depends on your set-up.
Old Aug 13, 2009 | 01:13 PM
inco9nito99's Avatar
Just with those mods, should be able to meet your goals no problem PUMP 93octane. E85 + 1450cc's on a BBK and you will SURPASS your goals by a fair amount .
Old Aug 13, 2009 | 03:39 PM
ETS Michael's Avatar
- BBK Full
- GReddy Ti catback
- ARP headstuds
- 880cc injectors
- Perrin air filter
- Tuned by Buschur
That's a good set of mods right there!
Old Aug 13, 2009 | 06:43 PM
Wht9er's Avatar
jeez i dont know about 1450cc injectors...arent those tough to tune on stock ecu? i think 1200s would be plenty at that horsepower range. If you plan to auto x then your much better off with a green. the red has a bit too much lag.
Old Aug 13, 2009 | 06:45 PM
merlin00069's Avatar
Agreed. I just hit 400 on pump and have a similar setup...except with the FP Red and minus the headstuds. Good luck
Old Aug 13, 2009 | 11:32 PM
Makinahoe's Avatar
You should definately achieve your goal with all those mods that is a well put together setup...
