what will be the best cams for 400/400
The 272s are good all around cams. I had 272/272s in my IX and when I swapped in a 280 exhaust cam (272/280) I picked up a solid 15hp from 6-8k rpms. The only reason I didn't put in a 280 intake is because HKS doesn't make one for the IX.
If you plan to upgrade your valvetrain you should go kelford 272s. Kelfords don't loose a lot of midrange but makes lots of peak power! Good Luck!
Wrong forum. Sticky: !If you are not posting a dyno graph, PLEASE DO NOT start a new thread!
Originally Posted by Noize
The title is self explanatory. Threads not adhering to the purpose of the forum with no graph will be locked and moved to trash. This is for dyno graphs only. Thanks.
if an evo 8 i'd say kelford 272, your best bet is to search these forums.AMS put up a GREAT thread on cam set ups, the power those cams make, etc.. as recompile said wrong forum. sorry mods, to add to this mess; however, to the OP use the SEARCH button! (it's your friend).
clip14
Aug 30, 2016 07:18 AM
Moore Auto
Evo X Dyno Results
64
Apr 8, 2013 10:12 PM
