DynoFlash Tune on my Evo 8
Old Oct 3, 2009 | 08:50 AM
  #31
IDRINKV8'S's Avatar
Originally Posted by kouzman
With the 388awhp that you mentioned before.
I am with dballz. Daily driven cars is better to run them with a safety cushion. Leave the full boost for the track
ella malaka lol...very high trap speed u had just saw your vid your problem is shifting if u can get that down packed your looking at a high 10"s to low,low,11's all day good lanching..
Old Oct 3, 2009 | 10:43 AM
  #32
5LEEPERISAH23I's Avatar
i dont get why every has to fight.. i was just posting up my dyno numbers just to say
Old Oct 3, 2009 | 11:04 AM
  #33
staatz's Avatar
Originally Posted by IDRINKV8'S
i dont know never took it to the track....sorry im addicted to high boost 30 to 31psi daily...lol..
You haven't gone to the track, so who are you to speak up about "detuning." For all you know your car may trap 110 itself. If you don't have factual information, maybe you should keep your words to yourself.
Old Oct 3, 2009 | 01:56 PM
  #34
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Nice better safe then sorry i like that too...i was told i wear cement shoes...lol..
I used to too but Allstate prefers my Nike Air's
Old Oct 3, 2009 | 02:00 PM
  #35
IDRINKV8'S's Avatar
dude you have no clue what your taking about....110 never will happen my friend made 320 on that extremely low reading..d.d.dyno and my car made a whopping 333 stock turbo,stock,cams,26psi pump one of the highest on that dyno ,it actually made 342 and was gonna make more but ran out of injector duty cycle...and now it's making well over 430 or more on that heart breaker so keep your comment's to your self and see your way out of this conversation pal....
Old Oct 3, 2009 | 02:03 PM
  #36
IDRINKV8'S's Avatar
hahhahah you dballz to many funny people and dumb comments that have no clue of what their taking about yo u might trap 99 miles lol...
Old Oct 3, 2009 | 02:09 PM
  #37
DBallz's Avatar
My trap speeds are right at where they need to be. I think everyone needs to chill and have a .
Old Oct 3, 2009 | 03:04 PM
  #38
kouzman's Avatar
The trap is ok. Probably i have another couple of mph left on the same boost with just better driving. If i can get 132-134 on straight pump with less than 30psi then i will be insanely happy with the car! Then we will do racegas or corn fuel...
Old Oct 3, 2009 | 03:07 PM
  #39
kouzman's Avatar
Personally i like your graph.
My first custom tune few years back was made by Dynoflash. I was happy with the car and it was trapping 114s @ 3500 lbs with around 23psi.
My fourth pass ever on the car with full bolt-ons was a 12.1@114 and that was driving first time ever my Evo @ a real drag strip...
Old Oct 3, 2009 | 04:10 PM
  #40
DynoFlash's Avatar
Originally Posted by whitey4d
This thread has flying poo... LOL.
For whats its worth every time my car was been on a dynojet it it was leaner and hit lower loads cells then it did on the street prior to going on to it.
The road checkup after a dyno tune is a good idea IMHO. My car has been on 2 MDs and 3 Dynojets. The car always run smoother on the MD then DJs especially when starting from a low rpm. Very close to the street when on a PROPERLY SET UP Mustang dyno.
a DJ loads the car too much at low RPM and not enough at high RPMs it seems to me after me expierences with both and the road with evoscan.
My procedure is to use the dyno to perform several functions
A - Verify power production is within desired range. In this capacity the dyno is a diagnostic tool which can determine of the car is functioning properly and qualtify the power.
B - Work out the maximum best timing values. With a dyno you can find the ignition timing values which result in the best TQ value and then back them off to a safe level.
C - Quanitfy gains or losses from tuning adjustments and or parts changes.
Once a car is optimally tuned on a dyno, IMHO any careful tuner will data log and check the car on a road going flat, slightly uphill and down hill. This allows to make sure the car is smooth and feels good also make sure the tune fom the dyno is safe.
Dyno numbers are only numbers.
I would like to add that 99% of the tuning I do is not on street driven daily driver vehicles. When a customer is trying to enjoy a high performance vehicle with minimal modifications as a form of principle transportation its only rational to keep the tuning on the safe side and err on the side of caution and long term reliability. All too often the fixation is on peak dyno numbers and not the area under the curve and the safe functioning of the car under a wide range of operating conditions and fuels used.
Of course tuning a highly modified race vehicle or project car which is intended only to push the limits is another proposition.
Al
Old Oct 3, 2009 | 04:12 PM
  #41
DynoFlash's Avatar
Thanks for the kind words. Your a true car guy and your passion for your car is evident.
All the best
Al
Old Oct 3, 2009 | 04:13 PM
  #42
DynoFlash's Avatar
I went to ICS Proformace. I was very happy with the tune! The car gave Al problems all day long. Just stupid stuff all day. But at the end of the day, it was running great! Very happy with the power it is making.
I drove 2hrs and 30mins each way to get there.. It was so worth the trip and will be returning there when i mod my car more.
AL is a funny dude haha and also a great tuner!
It was HOTTT day when it was on the dyno... 96 degrees the dyno sheet reads.. The car is running 24 PSI... Car made 351whp / 343 wtq
+1 to Big AL
Thanks for your business and appreciate you taking the time to share your experience.
Al
Old Oct 4, 2009 | 03:45 AM
  #43
IDRINKV8'S's Avatar
Yeah i see it happening with your car it has more in it goodluck with your goals..
Old Oct 4, 2009 | 04:25 AM
  #44
Sharkbite2000's Avatar
dyno or no dyno LOLOL, Al is too funny.
Old Oct 4, 2009 | 03:36 PM
  #45
DynoFlash's Avatar
Your da man ! Long time no see.
