Evo9 FP Red + Magnus v5 = OMFG!
Old Oct 4, 2009 | 08:21 AM
R/TErnie's Avatar
yeah stock throttle body
Old Oct 4, 2009 | 08:37 AM
fqjdmct9a's Avatar
Congrats!!!! Great Results..!!!
Old Oct 4, 2009 | 09:11 AM
CA$H's Avatar
I can't wait to get tuned!!!! I't probly going to be on your dyno...?
Old Oct 4, 2009 | 11:47 AM
97TSiAWD's Avatar
Very nice results. Those are amazing numbers, especially given the stock cams, head bolts, and long block in general.
It's also good to see results with the Magnus intake and the FP Red and even better to see how effective that intake is for making more power. I look forward to seeing your results once you upgrade the cams.
Old Oct 4, 2009 | 02:49 PM
JohnBradley's Avatar
Good work Eric.
You are very welcome to pick my brain whenever. Now I'd think about the SD though since at this level it will be some nice "free" gains. I found it interesting to note that your car makes the same power (albeit at more boost) and torque numbers as we did on "Jim's" car. He made 546/433 with cams and a little less boost. I am assuming that it must be because its equivalent airflow.
aaron
Old Oct 4, 2009 | 03:01 PM
dhammans's Avatar
What kind of o2 housing is that Ernie? That's something that appears to be a problem on a lot cars -- too much pressure in the exhaust/downpipe. I'm tempted to put a pressure sensor in my exhaust to see what it looks like when I'm up and running on the FP Black.
Surrounding the boost control, what ECU mods are you using on your car? I've got a Tephra 5.10 image that I've modified with the OBD2 test patches so the car passes emissions with no cat, and no rear o2 sensor. Are you using the MrFred boost control patches? I've got a Subaru STi boost control solenoid I am planning on using.
Also, shameless plug - I have a brand new in box Magnus V5 for sale. PM me if interested.
Old Oct 4, 2009 | 03:07 PM
tscompusa2's Avatar
im probably going to pick this intake manifold up for $750 from a local. im curious will my current piping work with the intake manifold and stock tb? or did you have to fabricate the piping?
Old Oct 4, 2009 | 03:09 PM
Requires a new UCIP and mini battery, ETS stocks them though so its only a phone call away. The stock TB requires being turned upside down but other than that its pretty straightforward.
Old Oct 4, 2009 | 03:11 PM
tscompusa2's Avatar
sounds easy enough, thanks man.
Old Oct 4, 2009 | 03:13 PM
tscompusa2's Avatar
hey actually i already got the small battery and a muse icp can you check my pictures in my profile and see if what i currently have will work?
Old Oct 4, 2009 | 05:41 PM
4g63evoeight's Avatar
nice work man, any port work to the exhaust manifold?
Old Oct 4, 2009 | 05:50 PM
UICP needs to have a lower entry into the TB. Anything that works with the stock manifold has to be modified to work with a Magnus....but its well worth it.
Old Oct 4, 2009 | 06:02 PM
Fast_Freddie's Avatar
Veteran: Navy
Great info Eric... and thanks for the props on making al this a reality... and to think, 6 months ago I was making more power than you and walking away from you on the "track"
Old Oct 4, 2009 | 06:09 PM
tscompusa2's Avatar
Ok thanks man! Im definitely getting this!
tscompusa2's Avatar
Also to the OP..... very good numbers for the mods!
