just tuned FP BLACK on E85, 35 psi, 2.3L Stroker.
Old Jan 20, 2010 | 02:34 PM
Liqquid's Avatar
Originally Posted by Kracka
Since when are forum members not supposed to make posts and express their thoughts and opinions?
SEARCH
sorry had to
To the OP:
Very cool to see those numbers with the old GSC's and stock head... nice!!
Old Jan 20, 2010 | 03:20 PM
penthouse's Avatar
Originally Posted by 1slowassevo
The hallmans to go to 34 u just have to change the spring inside to a stiffer one..I just looked at your sig your only making 460 whp on e85 on 30 psi something is wrong u should make 520 easy..
my brian crower272 and stock exhaust manifold holding me back. If i upgrade both intake , exhaust manifold and gsc s2, 520 will be achieved.
Old Jan 20, 2010 | 03:25 PM
penthouse's Avatar
one suggestion for u mr. 1slowassevo, be careful what u post brother, u might get banned again. Sorry for offtopic op.
Old Jan 20, 2010 | 03:28 PM
penthouse's Avatar
Originally Posted by Dr. SS
i was at 452 awhp 415 awtq on fp red @ 30psi
that is about right power as mine car. Every car will achieve difference power. Difference setup, tuner, ect..
Old Jan 20, 2010 | 03:38 PM
evowario's Avatar
ams ftw, nice#
Old Jan 20, 2010 | 03:42 PM
Dr. SS's Avatar
Originally Posted by lan_evo_mr9
Stock fuel lines, rail, and regulator?
yep all stock
Old Jan 20, 2010 | 03:46 PM
Dr. SS's Avatar
Originally Posted by darwin_evo
Are you constantly running this engine to 8K ?
am i? no, but on the dyno it was being pulled upto there i dont think i will on the stock valvetrain/stroker
Walt's Avatar
Nice #'s bro.. I can't wait till get my black tuned in a couple weeks. Just waiting on t- belt and should be back together next week. wish i had e 85 here but will be tuned on 93 pump for now. Good luck with new setup..
Old Jan 20, 2010 | 03:52 PM
Dr. SS's Avatar
Originally Posted by scheides
First off a FP Red should be in the neighborhood of 500whp on E85 on a good tune, good setup. The dude coming in and randomly commenting about that, GTFO. 460whp on a safe tune/mediocre setup is fine, and 520whp would be good power on a good setup/more aggressive tune. Coming in and randomly commenting about off-topic isht is pointless and annoying!
Dr. SS, nice power! 575whp is no joke! With headwork, some mean cams, and some sort of uprated intake manifold the thing will hit 600 easy, just get it to hold torque a bit better up to 7000+ rpm and you'll be there. IMHO: MAP stage3 head on stock valves, S2 cams, GSC springs, and your choice of intake manifold, depending on what you like to use the car for. If top-end is your only concern, maybe 1mm valves and DI or Buschur SMIM would be the way to go, otherwise a MAP Rev3 IM and stick to stock (or stock-sized) valves.
I recommend the MAP head b/c I have one and have seen the work first hand, its top-notch, great bang for your buck, esp if you stick with stock valves. I saw +10-15whp/+15-20wtq on my little BBK @30psi...otherwise there are plenty of others out there doing headwork, no doubt about that
thanks! yes i will look into map head.
450 /415 on the red was again on a evo 8 not 9, stock head, old school GSC cams, and stock everything else with e85 and 30 psi.
Old Jan 20, 2010 | 04:23 PM
boostedwrx's Avatar
Nice #'s dude! I usually see AMS #'s in SAE correction, so it's nice to see an uncorrected graph for a change. Are you running out of turbo up top or is anything else holding it back from 6-7k? *ah edit I missed stock head, etc*
Old Jan 20, 2010 | 04:31 PM
Dr. SS's Avatar
yep stock head. could use more spark as well.
Old Jan 20, 2010 | 09:32 PM
EVOlutionary's Avatar
Originally Posted by Liqquid
SEARCH
sorry had to
To the OP:
^^ this guy's got a slow car so don't listen to him !!
BTW - to the OP - your power curve down low looks AMAZING. You are making nearly as much power between 3-4K as I am on a 2.0L and an original Green on E85, but it completely walks away once past 4K . . .
EVOlutionary
Old Jan 20, 2010 | 09:59 PM
Boricua_Evo's Avatar
That's some serious power!
Old Jan 21, 2010 | 07:05 AM
penthouse's Avatar
hey dr.ss, u had the red before, could u tell the difference between red and black once u floor it. ?
Old Jan 21, 2010 | 02:01 PM
Liqquid's Avatar
EVOlutionary
damn word gets around
EVOlutionary
Could there perhaps be a 2.3l in your future?
