BBK Full, pump gas, VDR Dyno chart
Old Jan 26, 2010 | 07:36 PM
penthouse's Avatar
thanks man
Old Jan 26, 2010 | 07:48 PM
MJ23FE's Avatar
sccchweeeeeet!!!
-Jalal
Old Jan 26, 2010 | 09:29 PM
GHOSTN's Avatar
sorry for lack of knowledge but are these figures similar to a dynojet or mustang?
Old Jan 26, 2010 | 09:33 PM
burnzy's Avatar
any charts with meth switched on?
Old Jan 27, 2010 | 06:32 AM
John F's Avatar
Originally Posted by scheides
I've been seeing more and more people post their VDR dyno charts in this section, so I figured I'd post up mine. I installed my SpoolinUp COP a few weeks ago and these are the logs I got from testing it out.
Pump gas, 3rd gear pull, ~25psi. Ambient temp was -2°F.
I noticed you aren't using weather correction. There will be a significant difference in power between -2deg and summer temperatures.
Old Jan 27, 2010 | 06:46 AM
scheides's Avatar
EvoM Moderator
dynojet.
Not in this thread, but search around in this dyno forum; I've made plenty of posts clearly demonstrating the benefits and safety of a good meth injection system
No one else uses it, or bothers to include the data/settings they used in their screenshots, why should I?
Old Jan 27, 2010 | 06:52 AM
scheides's Avatar
EvoM Moderator
Originally Posted by warp9
Pretty damn impressive! Power level looks familiar
Hell yea man! A little BBK making the same power as a FP Black? It's all about the combo
Old Jan 27, 2010 | 07:54 AM
John F's Avatar
People should use weather correction if they want to compare logs in a meaningful way if there are temperature differences. At -2 deg F there is a 10.5% correction factor for temperature. It is not a valid argument to claim power gains due to modifications if there is a significant change in temperature between two logs, not that you are.
Old Jan 27, 2010 | 08:16 AM
94AWDcoupe's Avatar
and the response of bbk makes the car twice the fun of a laggy black.
all about the golden rule.
always use the smallest turbo to meet your HP goal.
Old Jan 27, 2010 | 08:20 AM
Mellon Racing's Avatar
scheides that's really impressive for 25psi, I'm sure the cold weather helps but damn that's good for a BBK Full on pump.
Old Jan 27, 2010 | 08:47 AM
CBRD's Avatar
the little turbo that could.
cb
Old Jan 27, 2010 | 09:53 AM
darwin_evo's Avatar
Well, there is this thread on here showing an fp black power curve using vdr, and the peak torque is at abt 5250rpm, ie: 150rpm better spool than the bbk full!
Of course this is not true in real life, just like a bbk full producing the same power as an fp black is not true in real life
Old Jan 27, 2010 | 10:01 AM
penthouse's Avatar
________________________________
wow, never heard of smallest turbo getting lots of horses
Old Jan 27, 2010 | 10:24 AM
zeus1's Avatar
that is pretty impressive for "lower boost" my green with mods in my sig (temp around 20 or so) made 420/426 with the exact settings as you but smoothing was 12. congrats looks like a fun ride.
Old Jan 27, 2010 | 11:06 AM
I think the Buschur dipstick retention spring he listed is what's making all of the difference
