Mustang Dyno steady state question
Old Feb 24, 2010 | 08:35 PM
blackevolution8's Avatar
Ive been on a mustang dyno twice and I am heading back again in a month. I have had difficulties while trying to tune steady state and cruising speeds. I try to find MBT but the torque number fluxuates so much (anywhere from 5-10 ft lb of torque at a time) that I cant find the point where torque falls off. Is this a common occurance on a mustang dyno? I did some tuning on a 350z using a dynapack and the torque numbers were clear as day and MBT was easy to find. Any help would be appreciated!
Sorry if this question is in the wrong section.
Old Feb 24, 2010 | 08:43 PM
GST Motorsports's Avatar
Are you having it hold at a certain mph/speed or just vehicle simulation?
Are you logging TPS as well?
- Bryan
Old Feb 24, 2010 | 08:45 PM
MPH. Ive tried 30mph up to 55mph and i get the same inconsistencies.
Old Feb 24, 2010 | 08:48 PM
And your TPS is 100% constant? I wonder if the loading is a little odd on that dyno
Are you doing the steady state in the same gear you synched?
Since the dynapak is attached to the hubs you can basically set the dyno to maintain speed and load which I would imagine is easier for MBT tuning.
I've done some steady state MBT tuning on our mustang dyno and I did some fluctuation but nothing as broad as what you are describing. Maybe drink less coffee that day?
- Bryan
Old Feb 25, 2010 | 06:28 AM
PeteyTurbo@KHC's Avatar
Don't use tow hooks to strap it down, try using control arms.. I do steady state on multiple mustangs and the only problem I have ever had is the pau making the rotor glow red hot and almost catching fire, but it still held
Old Feb 25, 2010 | 06:41 AM
Philthy748's Avatar
The hydraulic load brakes on the Dynapack are no joke! Makes tuning a breeze...
Old Feb 25, 2010 | 08:37 AM
Magnumpsi's Avatar
I have never had an issue with it and I have used it to steady state a lot.
Bryan may be right maybe something is off with the load cell on the dyno you are using?
Good luck.
Mitch
Old Feb 26, 2010 | 09:42 PM
It may be the dyno. I actually didnt set the dyno up. The owner did but he tunes a lot of stis and several evos. Im pretty sure it was set of for 4th gear and I did a bit in 3rd but even in 4th it still fluctuated a lot.
We use the control arms to strap it down. It doesnt get a lot of movement in cruising speeds. Unfortunetally I havnt had any coffee at that point! Maybe I should drink more!!
Evo VIII 4o1
E85 / Ethanol
Nov 27, 2013 08:45 PM
steveyrich
Aug 2, 2012 07:38 PM
Eszterle
Jan 6, 2011 03:51 AM
tonyboy
Feb 28, 2010 05:08 PM
4g94T
Lancer Engine Management / Tuning Forums
11
Jun 20, 2009 06:04 PM
