Drifto's Twin Scroll HTA3076 E85 33psi
Old May 18, 2010 | 09:13 AM
  #46
boonkae's Avatar
Some noob question ....
Which one is a better ... HTA 3076 or FP GREEN 73HTA ?
Old May 18, 2010 | 10:34 PM
  #47
zebiraross's Avatar
Both are similar as far as the compressor wheel. the 73 flows 54 lb/min where the 76 flows a claimed 57 lb/min. But the 73 uses th 67mm turbine wheel that is used in the red. Where the 3076 uses the 60mm gt30 turbine wheel. I would expect both to make similar power. And you can get the 73 in a stock frame.
Old May 19, 2010 | 01:30 AM
  #48
EvolutionBoy67's Avatar
Can anyone answer my question. How this setup spool on a 2.4l Long Rod short block. The spool is already amazing on the 2.0l. Also if one were to use this turbo setup with a 2.4l could you use a t3 setup or would you have to move up to t4?
Old May 19, 2010 | 02:30 AM
  #49
tscompusa2's Avatar
what settings on vdr? i like how your torque curve is basically a straight line.
Old May 28, 2010 | 10:27 AM
  #50
Strm Trpr's Avatar
What size tubing did MPFab use for your Primaries on your Exhaust Manifold?
Old May 28, 2010 | 09:50 PM
  #51
Drifto's Avatar
I.D. is 1 5/8"
Old May 29, 2010 | 06:26 PM
  #52
XcreatonX's Avatar
very nice. I bet it is a blast on the street? I would like to see some pics.
Old Jul 31, 2010 | 08:33 PM
  #53
Strm Trpr's Avatar
Originally Posted by Drifto
I.D. is 1 5/8"
1.50" Schedule 10 Tubing is 1.66" ID.
Is this what you meant?
Old Jul 1, 2013 | 12:45 PM
  #54
EvilTechnology's Avatar
bump
Old Jul 1, 2013 | 12:54 PM
  #55
06MREvo's Avatar
Originally Posted by EvilTechnology
bump
Thread is almost 3 yrs old.......
Old Jul 1, 2013 | 08:44 PM
  #56
I know....still wasn't answered
Old Jul 2, 2013 | 12:44 AM
  #57
Ted B's Avatar
One could use the exact same setup on a 2.4L, with quicker spool being predictable. Given that Drifto has demonstrated the ability to squeeze just about all the power than can be expected from the HTA 3076 compressor in a divided T3 format, logic implies no reason, no advantage to going to a T4 with this turbo.
Old Jul 2, 2013 | 02:29 AM
  #58
94AWDcoupe's Avatar
were pictures ever posted somewhere of the turbo setup?
Old Jul 2, 2013 | 10:29 PM
  #59
Grimgrak's Avatar
Seeing as how buschur made 600whp+ on the hta 3076 on a single scroll. Can you inform me of the logic that dictates, a t4twinscroll wont benefit this setup by offering more flow area similar to a single t3?
Old Jul 2, 2013 | 11:44 PM
  #60
Ted B's Avatar
Drifto also made 600whp+ on the HTA3076 with a divided 1.06 T3 before he voluntarily detuned it. The 1.06 divided T3 will outspool a T4 of comparable A/R.
