HTa 35r AMS tuned!
Old Mar 25, 2010 | 03:47 PM
BLKCarbonEVO's Avatar
The stock block on a 35r is pretty safe. Your tq should be below 400-425 on stock block. There have be a few people but the 35rs on pump between 550-600hp and never lost the motor. I'm at 540/438 on stock motor and I don't have a problem. Don't be worried about your block.
Mikey
Old Mar 25, 2010 | 04:14 PM
1slowassevo's Avatar
Mikey
You lie mikey your only making 535 read your sig..lmao..As far as your power very low numbers for a 35 r put the boost to 28 psi and go for 500 whp all day with 400 tq your evo is gonna love it and so will you!!!!!
Old Mar 26, 2010 | 09:39 AM
ADASEVO's Avatar
I would say this is pretty conservative tune (nice & safe), but personally I would turn up the boost. GO FOR 500
Old Mar 26, 2010 | 07:18 PM
Ekoy's Avatar
You guys are a bad influance. Haha. I dont want to make a I blew my block thread.
My car already spikes to 26psi and trys to go more but the EMS stops it. I thought it was fuel cut because Im already at 95% with my injectors but my wideband never goes lean
Old Mar 26, 2010 | 10:54 PM
Adubb84's Avatar
True the 35R could easily go for more boost..but I agree with you on playing it safe until the motor is built so nothing explodes.
Old Mar 29, 2010 | 03:53 PM
Ludikraut's Avatar
Looks nice. Might have to hit you up for a ride sometime later this spring. What are your cam gears set to?
l8r)
Old Mar 29, 2010 | 04:12 PM
Svendiesel's Avatar
Youve got another 70wtq to go man till you gotta get nervous, crank it up
Old Mar 30, 2010 | 01:09 AM
Ekoy's Avatar
l8r)
I think they are set at stock settings. I never played with them, and they were on the car when I bought them.
By the way, Is it normal for slack to form in the timing belt after the car has been sitting for a few days? Slack will form inbetween the 2 cam gears and It feels like I get way to much play. As soon as I start the car, the timing belt tightens and theres no evidence of it being loose. Anyways Ill probably post a video of what Im talking about tomorrow in another thread.
Old Mar 30, 2010 | 02:05 AM
burnzy's Avatar
don't drive the car man!!! should ALWAYS be tension on the belt, if it's loose it will skip teeth and cause you to lose your engine, please get this checked out. Don't even start it again, you can lose your engine VERY quickly.
Old Mar 30, 2010 | 04:25 PM
red03evo's Avatar
congrats on the setup and #'s.
Old Apr 1, 2010 | 06:31 PM
jcroswell's Avatar
When I go big I'm going with AMS.
Old Mar 31, 2011 | 03:14 PM
rhd-jon's Avatar
good numbers man
Old Apr 3, 2011 | 06:49 PM
wtr's Avatar
wtr
great numbers
Old Apr 6, 2011 | 05:37 AM
ranz's Avatar
great work man!
i was making approx. same hp numbers on 25 psi .
Old Apr 6, 2011 | 06:05 AM
jtbell86's Avatar
Congrats really good numbers, +1 for a safe tune im staying around the same psi (even on E85) for same reasons.
