Top Speed tuned Evo 8 716hp on a 2.4L
Old Oct 8, 2010 | 06:56 PM
  #91
lillev23's Avatar
Originally Posted by SmurfZilla
Take a lot to run 8's. Low 9's are a def. Possibility. If you guys are running at Reynolds then it might.
We are definitely going to give it a try. His car is well under 3000 lbs and he has a good wheel and tire setup.
Old Oct 8, 2010 | 07:03 PM
  #92
BadazzCR's Avatar
Going to take alot to get this car into the low 9's or 8's. Since its 2.4L it will be RPM gear limited.
Old Oct 8, 2010 | 07:13 PM
  #93
lillev23's Avatar
I'm sure we'll have to take the 5th, but we will see how everything goes down at the track.
Old Oct 8, 2010 | 07:18 PM
  #94
signature sound's Avatar
subbin. good luck
Old Oct 8, 2010 | 08:52 PM
  #95
mrtalon20's Avatar
I cant wait to go to the track.
Old Oct 8, 2010 | 08:54 PM
  #96
mrtalon20's Avatar
Originally Posted by Brandon03Evo
what all was changed to make that jump in power at less boost...
Cam GSC S3 Cams are the way to go . The car was spinning the wheels on the dyno .
Old Oct 9, 2010 | 09:24 AM
  #97
Mike.p's Avatar
Doug showed me the vid....hahaha that fkr is BAD!!!!
Old Oct 9, 2010 | 09:36 AM
  #98
SmurfZilla's Avatar
Originally Posted by BadazzCR
Not true... FP White's turbo took a crap on the 3rd pull car is still fine, and the 42r evo never made it on the dyno because the car is having over heating issues.
Isn't what I typed? I wasn't slamming topspeed.
Old Oct 9, 2010 | 09:55 AM
  #99
mrtalon20's Avatar
Yeah man forgot to say that this is on the wilson intake and stock tb. Oh yeah 2.4motor built by myself.
Old Oct 9, 2010 | 09:58 AM
  #100
aka.ralliart15's Avatar
Congrats Marcus, you and Will should try to make it to the Florida Evo meet in Orlando, it's gonna be awesome.
Old Oct 9, 2010 | 10:06 AM
  #101
mrtalon20's Avatar
When is it and thanks man.
Old Oct 9, 2010 | 10:09 AM
  #102
Mellon Racing's Avatar
that's a badass bump in power, congrats
  #103
mrtalon20's Avatar
I'd like give a Special Thanks to MaPerformance, Greg @ GSC, AWDmotorsports, and last but not least my tuner Doug @ Top Speed in Atlanta Ga. Can I get a sponsorship?
Old Oct 9, 2010 | 10:12 AM
  #104
mrtalon20's Avatar
Thank Mellon your evo is the reason I got the silver . Man the GSC s3 Cams are the best out there on the 2.4 only 35 psi with wheel spinning the car made 697 the last time and picked up 100 HP at that boost level.
Old Oct 9, 2010 | 10:19 AM
  #105
It's on November 20th so you guys have plenty of time to plan lol (there's a thread in the Southeastern section)
what tires are you gonna run? Do you still have the purple wheels with the Hoosiers?
