FP Red + E85 + Stock Motor (cams)
Old Aug 15, 2010 | 08:09 PM
  #31
jtyler's Avatar
Not sure.
He changed the plugs on the dyno, brand new.
Old Aug 15, 2010 | 08:11 PM
  #32
4doorstreetbike's Avatar
From the graph the tune looks good the power is not falling off. How does the car feel??
Old Aug 15, 2010 | 08:14 PM
  #33
jtyler's Avatar
Yeah, the car feels amazing. At about 4000-4500 is where I can feel the difference between the Red and the stock turbo.
Old Aug 15, 2010 | 08:20 PM
  #34
jtyler's Avatar
There was an incident on the dyno.
On the last pull he did, at about 7000rpms something blew.
He thought it was a head gasket or water pump or something of that sort, so he stopped.
He said that he was going to be done on that pull anyways. He suggested I buy a new head gasket and ARP headstuds, which I did. His inspection of what happened was very poor and very little. He looked around for maybe 1-2 minutes to see if there were any leaks...Then pretty much wished me luck.
Got home only to find out it was the AC. There is a hole in it somewhere.
I emailed him back to tell him and only to hear the same thing. That he felt it was maxed and wasn't going any further.
I honestly think he was fed up with it because I had an EBCS that had to be switched and a Omni 4 bar that he didn't like, but who knows.
Old Aug 15, 2010 | 08:29 PM
  #35
check your pm
Old Aug 15, 2010 | 08:45 PM
  #36
PeteyTurbo@KHC's Avatar
I could see the 360-370 on pump but the E85 numbers should be higher for that boost level.. Process of elimination.. Do a proper leak down test first to save yourself some time..
Old Aug 15, 2010 | 08:52 PM
  #37
Curious pete how does your dyno read next to stm's or buschur's??
Old Aug 15, 2010 | 09:13 PM
  #38
I knew he wasn't gonna answer that question..
Old Aug 15, 2010 | 09:44 PM
  #39
evo8john's Avatar
heck i made almost that much on my stock 8 turbo with e85... good luck finding the issue man!
Old Aug 15, 2010 | 09:56 PM
  #40
nnb239's Avatar
Ever thought of getting a second opinion? This might clarify any of your doubts..
Old Aug 15, 2010 | 09:58 PM
  #41
GST Motorsports's Avatar
Originally Posted by 4doorstreetbike
THe shop should have gone threw this check list for him hate places that do this to people..Im starting to wonder about these shops that's why I don't trust to many of them.
what are u using a bkie pump or a compressor??Your car should have been dynoed in 3 rd gear that's the closet to 1.1 ratio it makes your whp and tq go higher in 4 th gear so your and tq are probably like 15 lower.
True but he could of done the guy a boost leak test check the plugs and do a compression test all in all takes like 45 min tops for everything..But your right he should have gone over the car himself.
You should open up a shop.
To the OP. I would recommend a proper boost leak test, then a leak down and compression check to make sure the car is at 100% or not.
- bryan
Old Aug 16, 2010 | 04:24 AM
  #42
EVO8LTW's Avatar
Originally Posted by sparky
EVO8LTW: I thought that all the other possibilities that you posited were insightful, except for #3. I can't quite visualize a 3" I.D. hollow, straight through pipe becoming obstructed with corrosion. Unless they were like huge cotton *****.
He said it was a Megan, so I thought it might be resonated.
Old Aug 16, 2010 | 05:58 AM
  #43
sparky's Avatar
OOOH! Perceptive of you to p/u on that detail, EVO8LTW. Now I understand where you're coming from. Thanks for clearing that detail up.
Old Aug 16, 2010 | 07:39 AM
  #44
jtyler's Avatar
No you didn't. Remember this is a mustang dyno. Thanks!
From another shop?
- bryan
I plan to do a compression test today, but as far as the boost leak I said that It wouldn't allow more than 2psi in...I could hear the air going in and if I removed a vacuum line it would let a little air out, but my boost gauge and the gauge on the pump/compressor would only go up to 2psi.
Originally Posted by Diddy69Art
what kind of fmic is that?
xi power
Old Aug 16, 2010 | 08:09 AM
  #45
SmurfZilla's Avatar
Did he gap the plugs? On stock ignition they need to be gapped down to about 22 or lower. I'm one step colder and still have some issues (COP is on the way).
