FP Red + E85 + Stock Motor (cams)
Old Aug 15, 2010 | 06:04 PM
jtyler's Avatar
Finally got the FP Red installed and tuned last week. Hauled the car over to Buschur and was ready for a tune! First did a map on 93 and then on E85.
David said he did not know what the bottleneck in the system is and neither do I.. I really am disappointed in the outcome as I was expecting more of about 400/93 and 450/e85...
Let me know what you think. Sorry about the pictures .
Mods:
FP RED (84mm inlet)
Jun 272 cams
Walbro 255
FIC 1450s
Omni 4 Bar
3" Intake / HKS Filter
3" Megan Racing O2/Down/Test pipe with Buschur Racing Catback
3.5" FMIC / LICP & UICP
Forge RS BOV
BR MBC
ACT HDSS Clutch Kit
Mustang Dyno
93 [27psi]
369whp
338wtq
E85 [34 psi]
404whp
401wtq
Old Aug 15, 2010 | 06:07 PM
kyoo's Avatar
do you have an o2 housing?
Old Aug 15, 2010 | 06:08 PM
ZWingerRyRy's Avatar
Have a boost plot?
Old Aug 15, 2010 | 06:10 PM
Bottleneck would be the walbro 255. Mine maxed out at 405 on a mustang also on e85
Old Aug 15, 2010 | 06:16 PM
jtyler's Avatar
Megan O2 housing.
I was checking other logs from members and it seemed the single walbro could handle a bit more than 405...
Old Aug 15, 2010 | 06:23 PM
4doorstreetbike's Avatar
Mods:
FP RED (84mm inlet)
Jun 272 cams
Walbro 255
FIC 1450s
Omni 4 Bar
Forge RS BOV
BR MBC
ACT HDSS Clutch Kit
Mustang Dyno
93 [27psi]
369whp
338wtq
E85 [34 psi]
404whp
401wtq
david buschur tuned this car???If he did and doesn't know the bottle neck im starting to wonder..First off you should have a double pumper with e 85 what's your idc??
Old Aug 15, 2010 | 06:26 PM
jtyler's Avatar
Yessir, he did.
I was also wondering the IDCs so I emailed him what they were so I'll get back to you on that.
I first planned to run a double pumper, but I saw a few dynojet graphs that had 500 on e85... I knew it'd be close to my goal but I thought for sure I could get about 450 on the mustang.
Old Aug 15, 2010 | 06:43 PM
Yessir, he did.
im confused who's dyno is this???
Old Aug 15, 2010 | 06:48 PM
jtyler's Avatar
Not sure, I just saw a couple of dyno graphs from other members.
Old Aug 15, 2010 | 06:54 PM
also was this bushur's dyno with the sheet you posted??
Old Aug 15, 2010 | 06:58 PM
jtyler's Avatar
Yes, sorry. That is my graph on Buschur's mustang dyno.
Old Aug 15, 2010 | 07:05 PM
Ok didn't see it cause it was cut of from the pic I cant believe he ran 34 psi with a single pumper on e85 You need a double pumper asap like this week or else back it down to 27 psi.your numbers are way low for those mods and boost levels..whats your afr's?
Old Aug 15, 2010 | 07:06 PM
EVO8LTW's Avatar
A few things come to mind as possibilities:
(1) Could the cams be off a tooth? Was the car particularly knock sensitive?
(2) Could your Magnaflow muffler be coming apart and have an obstruction?
(3) Could the test pipe be obstructed with corrosion?
(4) Is the air filter particularly dirty (I lost 70 whp on a car once due to a dirty K&N filter)?
(5) How's the compression on the motor?
(6) Boost leak check?
(7) Is the throttle plate opening 100%?
(8) Could the brakes be dragging?
Sorry if any of that is insulting. Just trying to come up with ideas. Good luck finding the culprit.
Old Aug 15, 2010 | 07:12 PM
THe shop should have gone threw this check list for him hate places that do this to people..Im starting to wonder about these shops that's why I don't trust to many of them.
Old Aug 15, 2010 | 07:15 PM
red03evo's Avatar
A lot of possibles there Rich.
One of the things I was thinking was that should have a double pumper. Also, to the OP 450 is a lot of power on that dyno.
