2005 gsr dyno results
Old Nov 6, 2010 | 10:29 AM
1991lx50's Avatar
Have a 05 with Megan header, downpipe, hks muffler and test pipe. 280 cams, manual boost controller, greddy blow off back into aem cold air intake, k&n filter, 255 fuel pump.
In the end car makes 300/300. Mustang dyno.
Tuner stated Injectors are maxed out. Suggestions? Comments?
Old Nov 6, 2010 | 01:40 PM
mrdevo's Avatar
I've seen tuners recommend injectors on some cars but the majority slide by. How much boost was this at btw?
Old Nov 7, 2010 | 01:07 AM
1991lx50's Avatar
22-23 psi
Old Nov 7, 2010 | 01:48 AM
Mwolf83's Avatar
1000cc injectors are a pretty common upgrade for people running pump and E85 up to about 5-550whp and can be made to run the car as a DD very well. Plus if the tuner is right about them being maxed you wont want to run them too long that way, injectors should be sized to about 80-85% duty cycle if you want them to last and run safely.
Old Nov 7, 2010 | 09:33 AM
mrdevo's Avatar
I have an intake 272s and a ic with the rest of your boltons too, never needed injectors. Made 339/351 22psi dynojet fwiw.
Old Nov 7, 2010 | 09:41 AM
1991lx50's Avatar
Thanks for ruining my day mrdevo. lol.
There is either a fuel issue like a bad pump, or something else. Havent met anyone with a car with my mods needs injectors. And they all make more power than I.
Old Nov 7, 2010 | 09:51 AM
Mwolf83's Avatar
That happens alot, Evos even stock to stock have huge power differences.
Old Nov 10, 2010 | 04:50 AM
2plaz's Avatar
get a better tuner
Old Nov 10, 2010 | 09:55 AM
EVOIXreno's Avatar
Thats pretty decent power for a mustang dyno.. MRdevo was on a dynojet whci reads 10/15% higher.. so you would be around 330 on a dynojet.. that not bad for the low boost either!
Old Nov 10, 2010 | 10:07 AM
alqubaisi's Avatar
Mustang dyno kills u .. !
