CBRD does it again. BBK full retuned... More power!!
Added a Synapse DV, Exedy stage 2 HD, and ARP head studs for peace of mind and headed to CBRD for some more tweaking. The attention to detail and fine tuning was unreal, dyno run after dyno run nothing left untouched. At just 26.7 psi which is about 1 psi more than my last tune the car put down 425 whp and 362 wtq. At 28 psi the car put down 436 whp and 380 wtq which is absolutely unreal. The car is set at 26 psi and to be honest I really don't need any more power, 1st gear is now worthless
. The attached chart is the 26 psi run, as that is what the car is actually making as it sits. I took the car to the track the next day. 2nd time at the dragstrip with street tires that are shot, I was able to run 11.49 at 122 mph. Best mph was 123.
Again the rundown of my mods:
BBK Full (not ported)
Precision 880cc injectors
ETS 3.5" Garrett Core, ETS ic pipes
Kelford 272's & FP beehives, ARP studs
Perrin Intake, Grimmspeed 3 port
Cheapest 3" tbe I could find, Standard megan style o2 housing
Synapse Dv
93 Octane, Everything else is stock, no porting ect.
I can finally say that the car is exactly where I wanted it. Thank you Chad for helping make this happen. Also big thanks to my buddy on here, 90tsipa for helping on all of the installs!
. The attached chart is the 26 psi run, as that is what the car is actually making as it sits. I took the car to the track the next day. 2nd time at the dragstrip with street tires that are shot, I was able to run 11.49 at 122 mph. Best mph was 123.Again the rundown of my mods:
Synapse Dv
Scheides - the synapse dv was the only addition power wise. You have the same reaction I did.
Thanks pizzaman, wow that puts the power into perspective doesn't it. Z06's are no joke
I am extremely happy with the exedy, Best clutch I have had so far in any vehicle. Little chatter with huge holding capacity in comparison with the stock clutch which is a perfect combo.
my best pull a year ago 369bhp at the wheels in the UK good results you have! i've changed me std bov to synapse and fitted a map rev2 intake and boomba throttle body and im having a Speed density map next week i can't wait
