EVO9, E74 and why you need a fuel tester
If you go by octane alone, ethanol wouldn't do what it does.
I'm not looking for a theoretical answer though. I'm curious if other then adjusting for AFR due to the lower ethanol content, does the tune really need to be any different? I've seen on what we have that passes as E85 (really closer to E60) in 4 cylinders making over 800WHP on it. Even at 60% ethanol, it still seems sufficient to allow MBT on almost any boost level on any setup.
When running it richer say 11.1 across the board vs 12.1 there is a slight difference uptop.. maybe 30whp or so (varies), but not enough to throw the tune off. but its wasting gas and e85 mpg is bad as it is, running it at 11.1 WOT is horrible mpg.
I dont know e60, hopefully Dave will respond to you, im sure hes delt with it before.
If you can pass max timing with e60 then theres your answer, but i only ever ran e85.
The ideal solution is to use a flex fuel sensor and have a 3d map which will compensate from pump gas boost and timing numbers to e100. Right now a lot of guys are doing this on the big $$$$ buids with Supras, Vipers, Vettes, Gallardos and other such high $$ cars. The sensor is not cheap and neither is the ecu to use the 3d tables. Right now I think Motec M800 based ecus are the "gold standard" for these tunes. In a less than perfect world you can tune for one concentration and if you notice your afr varying outside a predetermined limit you would know you have a different mixture. I would start with the highest concentration you run since more gas would run richer and be safer than leaning out. Just log your afr and pay attention after a fillup and see what you have.
We do similar calibration for catalyst efficiency maps over a wide sweet of temperature ranges.
Makes me want to dump the money for a Motec, Vipec, or Pectel ECU... but then again not!
ya i wish the stock ecu had better correction tables so we could actually force it to keep a consistent tune in any weather (afr wise) but i guess thats asking for to much. some standalones you can make it target certain afr's and it will auto correct right?
I'll get that E85 test tube eventually just to see what the station where I fill up is at
I think the station I fill up at has the lowest ethanol content out of 10 stations we have here in socal
My friend goes to a E85 station in san diego and the label says "85% ethanol content minimum" and he filled up at the station I go to and he did a couple WOT and on last run he blew his motor..............
Forgot to mention the station I go to says "70% ethanol content minimum"
I still made good power on it though
My friend goes to a E85 station in san diego and the label says "85% ethanol content minimum" and he filled up at the station I go to and he did a couple WOT and on last run he blew his motor..............Forgot to mention the station I go to says "70% ethanol content minimum"
ProEFI has the ability to adjust timing based on ethanol content.
Pretty advanced ECU:
http://www.youtube.com/watch?v=a1CzmmMUy50
I was debating on running this system, but the number of tuners is so limited, and e85 isn't too redily available in my area.
If I do go e85, I'd just get one 55 gallon drum, test the e85 before filling it up, and store it.
IMO pretty much a foolproof way to control it.
pretty cool gadget, but i only care about AFR control.. it was neat seeing how regular 93oct effected the ethanol content though as he filled it up. few tweaks to the IPW will fire a evo up first crank also dead cold on e85.
I love how that supra sounded though.. just a shame how bad he spun 2nd gear lol.. losing races due to traction isn't fun.
ProEFI also has an optional traction control system too.
Traction loss can be amusing at times
.Though nothing beats the grip of AWD.
David, have you actually noticed in power limitations regarding specifically on the ethanol content?
We get E70 around here, and it's been tested to be closer to E60 and yet guys are still making great power on it. I've also hear of some guys running more like E30 with 93 octane as the base fuel and it working well.
Obviously the AFR changes if the ethanol content changes, but does how aggressive of tune you run really change at all?
There is a very noticable difference in E70 to E85 when tuning, fuel requirements and maximum timing. I'd highly recommend getting a meter so you know what you are getting. Then there is the problem of mixing the fuel from one station to the next as some are very slow to switch back over to E85.
If you have big swings in your area or fill up at different places you should definetly be testing your stuff. Zeitronix offers this lil' gadget:
http://www.zeitronix.com/Products/ECA/ECA.htm
It's about $500 for the whole setup but that's alot less than an engine rebuild.
edit, nevermind. i see it goes in the return line, not in the tank.
We are lucky enough to have a station close by thats E95 from the pump.
