FP RED Evo8 expectations??
Old Jan 1, 2011 | 10:23 PM
albalushi85's Avatar
Dear All,
I am going to install my FP RED soon. I only wanted to know how much whp & wtq shall I expect with the following modufication:
HKS 264i/272e cams
Vishnu cam gears
BC springs and Retainers
ARP Head Studs
ARP Conrod studs
HKS Air intake
Custom Intercooler piping
SSQV blow off valve
Exedy Twin Clutch
Boucher Full turbo Exhaust
RC 750cc injectors
APR fuel Regulator
HKS 1.2mm HeadGaskit
Keeping on Mind that the car will be tuned on 93oct fuel.
Please advice so I can know if things going right or wronge!!
Thanks and Regards,
Old Jan 1, 2011 | 11:11 PM
Draven83's Avatar
no body can tell you, it all depends on your tune and other things like that. I say about 375 if i have to guess.
Old Jan 2, 2011 | 06:21 AM
zeus1's Avatar
depends on the tune, dyno etc. many variables. best thing for you to do is to make sure you have a set of fresh plugs gapped propertly and do a boost leak test prior to the tune. also ask your tuner what comprable cars have done so you have a rough baseline to work from.
also on a side note i do not think this bov (SSQV blow off valve) works to well on our cars and do you have a Front Mount Intercooler. You might want to invest in one.
Old Jan 2, 2011 | 06:48 AM
grillpt's Avatar
I don't know how much power you"ll make, but I can tell you those HKS cams will hold you back. If you already have springs and retainers installed, I would look to run something more aggressive such as Kelford 272, GSC S2, or FP4R's. Good Luck.
Old Jan 2, 2011 | 09:06 AM
dastallion951's Avatar
well to give u an idea, ive got similar mods to u , but a couple more, and in the mid of july on 91 octane only i made 385 on a dynojet, but i had hks 272 i&e cams, so with your mods if your goin on a dynojet dependin on 91 or 93 octane, im gonna give u a ball park of 350-400whp...dependin on ambient temp etc....
Old Jan 2, 2011 | 12:06 PM
JDM EVO PANAMA's Avatar
You need o2 housing and better cams.
Maybe even injectors and you can break the 400 whp barrier.
Old Jan 2, 2011 | 04:17 PM
tscompusa2's Avatar
if on stock front mount the car will be very held back.. but if it has atleast a decent 3.5" id say it will make about 450 dynojet on 93oct.
Old Jan 2, 2011 | 04:30 PM
phrequenc's Avatar
seems like a lot of work to get 450, sounds like it would be way more than that to me.
Old Jan 2, 2011 | 04:46 PM
tscompusa2's Avatar
keep in mind its 93octane. i did a fp green 73hta @ 24psi making 430whp. the red is bigger then the fp green, so there is more power yes.. but if theres any kind of bottleneck at all in the mod list the power is out the window and wont be possible to achieve.
Old Jan 3, 2011 | 12:08 AM
Dear,
I ve got the O2 housing already, Regarding the Injectors I ve got the RC750CC which is not yet installed.
Waiting for the Turbo to arrive and hope I get somthing arround 420-450 whp. then I will be saticfied.
FYI, Planning to change the 264i cam to 272.
Thnx for feedback
Old Jan 3, 2011 | 12:11 AM
tscompusa2's Avatar
Originally Posted by albalushi85
Dear,
Thnx for feedback
and FMIC = ?
Old Jan 3, 2011 | 12:21 AM
hi,
I got my new fresh HKS plugs on hand already, my tuner did an Evo9 with tomei arms and he managed to get 390whp/370wtq, and as per my knowllege that the RED can do much better than Arms.
I have stock intercooler though
Old Jan 3, 2011 | 04:26 AM
zeus1's Avatar
i would seriously invest in a front mount intercooler
Old Jan 3, 2011 | 04:35 AM
tscompusa2's Avatar
hi,
get minimum a 3.5" fmic.
Old Jan 3, 2011 | 07:14 AM
Its more than just the turbo you need the right intercooler, cams, injectores and ect to make power.
