Quote:
I think he was referring to how it's not holding 26 psi all the way to redline.Originally Posted by fightex
i haven't had too much problems with surging. only when i'm trying to hold 8-12psi up hill for 3-5 seconds then it surges a bit. otherwise, it seems fine. thanks for the tip though
nice job. It's nice to see another person very pleased with the HKS 7460. Such a great turbo IMO.
Quote:
i got the turbo slightly used from TekiZero and Justin assured me that the wastegate actuator has been tightened correctly. IIRC he made ~480whp with a few more bolt ons on VD running E85. i think the elevation probably has to do with the turbo not being able to hold boost Originally Posted by GG06MR
Quote:
if i wanted more power, i'd just add more parts - intake/exhaust mani, meth, SD etc. i don't do roll-ons on public highways, and i like the 1/4 mile as much as the next guy so this turbo makes perfect sense to me Originally Posted by R/TErnie
Quote:
i'm in Edmonton, Alberta Originally Posted by DeMoNz
where in Canada do you reside in?
Quote:
No, not in shootout mode. The "ATMC1" tag on the upper left corner of the chart indicates that the weather correction is applied. The dyno software has different types of weather corrections (ATMC1, ATMC2, SAE, IAT only). First two is from Dyno Dynamics.Originally Posted by evo4nr
Is this ran in shoot_44?
As for the boost at the top end, the car didn't make any more power when boost was set ~1.5psi higher at the top.
Those numbers seem right for a DD dyno...yes they read low, as in very low
Good looking graph though, looks like a fun setup.
Roughly 15% difference between 1.0CF DD and a dynojet.
