V.D results, sc61 kit, built engine 31psi 93 oct.
Well I dont know if the V.D dyno runs count but here it goes. If this does not count mods please delete.
I recently did a few things to the car and it really felt like it picked up good power. Most of the credit goes to the new buschur bf272s I installed in the car. I recently did a drop in piston wiseco h.d. pistons, eagle rods, bf 272s, and buschur valve springs. The car now seems to love pump gas and pulls great! The car previously put down 522 on the same boost with comp280s and a stock long block on a dyno jet. Onto to the results-
Full mods..
Wisco hd. pistons 9.1
Eagle rods
Buschur bf 272s
Buschur vavle springs
JMF drag intake mani
JMF intercooler pipes
JMF intercooler
Ets sc6152re turbo kit with a .63 hot side.
AFI 1000cc injectors.
Walboro 255 hp fuel pump
halman pro boost controller
s.d. tuned by me
93oct
31psi falling to 28 psi.
V.D seetings
weight- 3470, This is a full weight ssl car, it weighed in at 3489 with me in it.
Stock tire height
Full mods..
Eagle rods
Buschur bf 272s
JMF intercooler
s.d. tuned by me
93oct
V.D seetings
Stock tire height
92 % duty cycle at peak. About 11.3-11.4 afr on my aem wideband. I dont expect the car to make this exact number. I know the car pulls a lot harder then it use to though. I will be hitting the local dyno again soon, hopefully the end of this week. Should be neat to compare the real dynojet to this simulator.
I dont know what it picks up per psi, I only used this v.d. dyno thing tonight for the first time. The car peaks 31 psi by 5k and falls to 27.7 by 8700. I think the .63 causes the drop in boost.
I have a .63 and hold 30 psi till redline..I logged the car the other day and boost was lower due to hotter weather it was 28.5 from 5,100 rpms till 8,000rpms
lol its a oldie but does the job. I have a .82 hot side sitting around for this turbo I may throw on sometime. It's just the turbo is in great shape, b.b., no smoke no muss no fuss so I plan on running it until the wheels fall off
