My VR Dyno after new tune
Ok well I got a new tune via TSCOMPUSA/VR Speed and all I can say is wow its amazeing. The car is set at 27 psi holding 26 through redline this is all on 93oct.
keep in mind the AFR was just flat 11 across and the spool has some more tweaking in it.. I will fix the AFR once the weather breaks into the summer heat so i dont have to keep tweaking it.. its been going from 60F to 30F the last few days.
he will be tuned on e85 also next
also this is the new VD.. that uses smaller smoothing ratios.
heres the graph with a smoothing of 5.
Major mods:
FP red ported /w 18psi wga
ETS 3" uicp & 2.5" licp
ETS 3.5" fmic
Jm fab air intake system
ARP studs
fic 1050cc
FID exhaust manifold
Comp 272 cams (mild cams)
Map SS o2 housing
HKS EVC 6 EBC (badass boost controller)
3" turbo back exhaust
ACT XTSS clutch
Sparktech non cdi
Turbosmart raceport bov
Tephra v7 SD using fuel temp as IAT.
omni 4bar map sensor
Major mods:
ETS 3.5" fmic
ARP studs
fic 1050cc
Map SS o2 housing
ACT XTSS clutch
Sparktech non cdi
Major mods:
ETS 3.5" fmic
ARP studs
fic 1050cc
Map SS o2 housing
ACT XTSS clutch
Sparktech non cdi
Major mods:
ETS 3.5" fmic
ARP studs
fic 1050cc
Map SS o2 housing
ACT XTSS clutch
Sparktech non cdi
lucky you can get e85. fp red is a turbo i have been contemplating but like my car now. extremely quick response and pulls like hell for the old green
( do mainly stop and go)
