FP3794 + EnglishRacing 2.4
This is the log for 794 in 3rd (3586)-
Aaron
Here is a 4th gear (3794) to 3rd gear (3586) that shows the same power at less boost which supports what everyone would think about big vs smaller-
Here is another one at high boost that seems to indicate otherwise. The only reason I say seems to, is that now I realise I probably didnt have enough load in the load control and was in 3rd so the boost didnt ramp the way it would have in 4th for a fair comparison-
What are the parameters that the dynojet uses to calculate with? Also what is the inertia weight of the rolls? Did you hve the pau on the dynojet for the 3586?? The parasitic curves may be off which can yeild drastic changes in hp as roller speed increases. Adding load to the rollers should not gain hp, it should help make more tq. though since the spoolup would be a bit sooner..This is under the assumption there is no wheelsin though
Either way the new snail looks to be working very well, awesome numbers.
Dynoing in 2 different gears and 2 different ambient temps doesnt make this test very scientific or accurate.. The car will show completely different power curves from 1 gear to the next.. While i love both turbos this testing shows that 1 is extinct which is not the case.. There will be MANY upset people who swap an 86 looking for power with no loss of spool if they follow these results.. Mark my words...
here is a quote from the guy who builds these turbos when i asked is this physically possible....
Robert..
"comparing different turbos in different gears with different ambient temps is not a valid comparison"
Robert..
Robert..
Robert..
Got to agree with Mike on this one - it's no way an accurate comparison...
Still some pretty sick power and spool Aaron - congrats on piecing it all together and congrats to everyone involved with the build!
I want a ride in this bish when I come down next
Robert..
Robert..
Those last 2 comparisons are within 10* ambient temps and 10% humidity. While it is not exact it is very close. I can post the 3rd gear to 3rd gear if you want to see that as well with the conditions as close as possible (aforementioned).
This supports what I already said earlier though, if I had run the 86 in 4th as well the extra load makes the difference. The 94 whips through the pull too fast and the boost doesnt ramp up fast enough in lower gear. We see this in the quads all the time, they dont get enough load in low gear because of spin normally they arent at full power till 4th.
This is why I am starting to see what Dave said about the Mustang and its load control and using higher gear for all the tests. All my data is based around 3rd gear because it always worked, now I am past that point so I have no real comparison. Load control could have made it more comparable. Petey, the Dynojet uses a ramped percentage I am not sure on the actual load value on top of the 2500 (x2) rollers and Linx belt locking it together.
Put it on the street and it makes all the difference, its 21psi at 4200 just like the 86. I cant explain it, its what it does. There is no bottle in the car, I didnt modify the MIVEC further, the change is the turbo and testpipe dump.
For a street car I would not recommend the 94 as a choice if the other one was the 86. At 26psi I am now down about 50whp, it doesnt even out till around 30psi. The 86 is alot more fun on the street.
Aaron
Aaron
Thanks for sharing Aaron! congrats.
I was just saying I looked at that first dyno plot and thought it was a comparison between turbos, not a comparison between gears. Mike and I made the same mistake while reading the post. I took comfort in that I wasn't the only one mistaken. No smoking :/
time for the EFR9180 Aaron.
