Stock turbo + full bolt ons.
To most people who said it's 2.0 ( I agree) but it's AWD. It should move faster at a stop than most of the car out there. My torque doesn't get on until 3000k and I don't go higher than 3000k regular driving. My exedy twin clutch takes a few second to move in 1st gear ( moving too fast would stall the car). <<<---That and the no low torque( stock turbo) kept me thinking "why there is no low end torque"?
Yeah that is i'm hoping for new set up but no cams for now, just the hta green and other supporting mods. I'm sure it gonna be close to 400.
well as far as turbos go of all choices out there, since your complainin about low end torque boom right off the line take off and go, the hta green bar none is one of the best overall low end with good midrange and top end turbos that are on the market today...good luck, recommendation throw some gsc s2s and springs/retainers with that turbo, ull hit 400 thats for sure...but without cams on a hta green unless its cold as hell and uve got 93 octane, i dont see 400 hp on pump gas.
maybe look into getting a 2.3L stroker or 2.4, it will make the turbo spool even quicker and give you more low end.
when comparing these cars curves to v8's and etc it is disappointing, but we can rev much higher also.
Thats really interesting! i made about 360awhp and 358 awtq... pretty much the same set up and boost as you are! great numbers! I would post up my graph, but i lost it along with my registration card!
i think you'll be pleased with the hta green. that with good mivec tuning and you should have about 30psi of boost by 3500rpm, which i think you will adjust to easier. with these cars you have to sacrifice a little bit of low end power for an increase of overall power.. keep in mind they are still only 2L engines and without the turbo they only produce around 180-200hp flywheel.
Ill be on the look out Tom, keep up the good work man
well not to debate with u but with my mods and fp red with hks cams on 91 octane in summer i made 385 on a dynojet, so like i said it depends on gas mods and ambient temp.
you wont break 400 on an hta green on pump gas without cams , unless its tuned to the edge. And if by chance your factory freak does break that barrier, then better start savin for a built engine, or clutch for that matter.
Like I said it might be closed to 400 on a dynojet but since the weather is so hot now it South Florida, it's about 85 degrees, I'm afraid that would be the problem. Diiirk at AWD will be doing the tuning so that is even better.
One of my friend has a V8 mustang and i am dissapointing everytime i drive next to him.
