Help me find my power! Dynograph inside
Sup yall, I feel like my car is down 60 to 80whp. I will be gettin it retuned in about a week or so with the same tuner/dyno. I just want to make sure that I have every option covered.
Red line (356.75/329.61) 23 psi 93 oct. Mods at the time were as follows: Stock turbo, stock ex manifold, stock O2 housing, Comp 272 cams, Arp head studs, 780cc injectors, 255lph fuel pump, 3" downpipe, 3" test pipe, 3" cat back exhaust, ETS 3.5" FMIC-INTAKE-UICP-LICP-RECIRC PIPE, Crushed IX bov, Hallman MBC, AEM Wideband
Green line (368.96/334.10) 25psi 93 oct. Mods at the time were as follows: MAP SST Turbo ported+coated, FP 25psi wastegate actuator, 4WS Mona Lisa Tubular Manifold, MAP 3" O2 Eliminator Downpipe, GSC S2 cams, EVERYTHING ELSE REMAINED THE SAME
http://www.flickr.com/photos/26373413@N06/5641267515/
With so many upgraded parts I def expected to more than +12/+5. I expected this set up to be at least 430whp. While the car was on the dyno the tuner stated that the boost was spiking to 31psi with the MBC barely turned up. He did not feel comfortable tuning the car at 31psi on 93oct and I didnt blame him. So he disconnected the MBC leaving me to be tuned on wastegate pressure. Im hoping/thinking that the 25psi wastegate actuator combined with the "big spring" in the Hallman MBC was the cause. To fix this I have ordered a Omni 4 bar and Grimmspeed 3 port. The tuner also stated that my compression may be the cause of the numbers. At a later date a secondary compression test was performed. The numbers were not flawless but they were on par for a car with 117k on the clock. They were well above the min allowance of 138 too. I have been told that big cams can affect the compression some as well. I have reached out to several sources and they have all stated that my compression results would not have been the cause at the power level. Lastly my car doesnt SMOKE, RUN HOT, or BURN EXCESSIVE OIL.
Just for ref I talked to MAP about this turbo a long time ago and they tuned it around 27-28 psi on pump. I know that tcompusa has tuned an evo with this turbo and it got pretty good results too.
Honestly, Im stomped. Do yall have any ideas or suggestions that I can look into on or before my next tuning session? I want to be as helpful as possible to the tuner and get my car where it should be powerwise.
*MODS, if this is the wrong section just let me know and I will move it.
**The point of this thread is to get my car on par. Not to bash a shop/tuner. At least they are offering to throw it back on the dyno t get it sorted out.
wow.....somethings up for sure.
can you get a boost compare / overlay for both of the runs you have in your power compare?
who does all the wrenching on the car? do you still have your stock turbo & exh mani?
Well, spool looks real good, and the power doesnt drop off too much at redline, im thinking it's the tune, you should send the map to Mellon, english racing, or Vrspeed and have them check it out, you should easily be at 400AWHP at that boost level with those mods, the SST turbo isnt much better than say a FP WHITE though so dont expect big numbers but it should be able to put down 450 ish on a dynojet with E85.
I sold my stock turbo and exhaust manifold after I purchased the new stuff.
I downloaded my map and it appears that its locked. I assume this is common practice for all tuners to preserve their work
Your stock throttle body seals i guarantee that they leak... mine leaked horribly at 50k miles let alone 117k+.
Talk to Mil.Spec about his high pressure seals. Thats what i have and installed them and now noooo leaks at the trottle body just every where else lol.
https://www.evolutionm.net/forums/ev...available.html
And i agree ^^^^ possible bad timing and maybe knock???
Im not discrediting the notion of leaks. I will do a boost leak test. The car doesnt have any issues with holding boost though. I was thinking that if it had bad leaks or a huge one that I would have issues holding boost.
secondly, looking at a boost gauge will not determine if you have leaks. You can have a nasty leak and the turbo will simply spin faster to compensate. That creates a lot of extra heat and kills power and turbos ultimately.
my advice would be to do a proper boost leak test with an air compressor and find a tuner that doesn't lock you out of your own ecu. Hopefully you just need a definition file and it's not really "locked".
